Originally posted by VE2CJW Paul. The tests I have been doing lately have been of shooting geese in the water at about 300 feet with not perfect lighting. I tried auto and manual focusing and used a tripod. The problem in focusing is that the geese are quite far so they don't fill the screen. It really isn't a perfect scenario. I have done some testing of my DA L 55-300 with resolution charts and the results are perfect. I have also tested the lens for front and back focus problems with excellent results. I always carry the 55-300 in my bag because I often need the range it gives me. I was wondering is a Sigma 120-400mm would be very much better to justigy the price difference. The pictures I have looked at in the reviews are not very impressive sometimes.
Probably the best idea would be to just try a 120-400mm and see if it meets your requirement. Since you've tested carefully with your 55-300, you'll have a good basis for comparison. It won't take you very long to determine if the 120-400mm will meet your expectations. I think you're at a point of very small performance differences where you can't rely on others' experiences with different copies of lenses than you have.
My point about the 120-400 is that you might indeed not carry it in your bag all the time as you do with the 55-300, but there again it can be hard to judge without having the lens in hand, and you can't rely on whether other people report they carry theirs or not. There are probably people who drag a 400 2.8L around all day, but that doesn't mean that most of us would, even if we could afford one. And keep in mind that you'll need to make up that 70-120mm range with some other lens, unless that Panagor entirely meets your needs in that range.
Paul
