02-07-2013, 11:37 PM   #1
Is your Helios 44 swirly?
Does your Helios 44 produces swirly bokeh? I am unable to get with mine (44K-4) even at MFD. Although bokeh is very smooth, I was expecting swirly effect at MFD. Seems like I am missing some trick.
Any idea?
Thanks
02-07-2013, 11:50 PM   #2
RickyFromVegas's Avatar
Not all Helios 44 will produce that swirly bokeh effect.
Older 44-2, for example, is a great one for swirls. 44k uses more blades and elements than the older designs, making the swirl less noticeable than its predecessors.
02-07-2013, 11:57 PM   #3
I don't think blade count has anything to do with it as I was shooting wide open (anyway it has 6 blades only), you may be right about optical design change though.
02-08-2013, 12:15 AM   #4
My 44M produces swirls, so this might just be a copy by copy effect?
02-08-2013, 12:35 AM   #5
boriscleto's Avatar
My 44M is not nearly as swirly as my 44-2.
02-08-2013, 01:33 AM   #6
QuoteOriginally posted by yusuf Quote
So far I haven't seen my 44-2 swirl either, and I use it wide open most of the time. For it to swirl, I believe you have to stop it down a bit and have the highlights beyond a certain distance.
02-08-2013, 01:36 AM   #7
kiwi_jono's Avatar
Mine (older one) sometimes looks swirly: Hill Flowers | Flickr - Photo Sharing!
Cant remember if this was wide open but if not it was nearly so.
02-08-2013, 01:56 AM   #8
I have the 44k If I recall I got the best swirl with target in focus at just over the minimum focus of the lens around 2.5-3 ft
02-08-2013, 03:10 AM   #9
Pablom's Avatar
QuoteOriginally posted by RickyFromVegas Quote
that is exactly what I experience with my 44-2 and 44K-4, of course it depends heavily on the background.
02-08-2013, 04:16 AM   #10
ihasa's Avatar
QuoteOriginally posted by kiwi_jono Quote
Lovely shot! Love the contrast between the blue petals and red stamens. Not mad keen on the swirl in this context although it doesn't spoil the shot.
02-08-2013, 04:21 AM   #11
ihasa's Avatar
I have the k-mount version of the lens, six blades I think.
http://farm6.static.flickr.com/5026/5696562199_8051af9842_b.jpg
02-08-2013, 04:42 AM   #12
From what I can tell the swirl effect appears in the background of your subject.
Demonstration:
PENTAX K-30  Photo
02-08-2013, 08:05 PM   #13
Otis Memorial Pentaxian
Huh? The 44K has six blades, the same as all the auto-aperture Helios 44, save the Helios 44M (no hyphen) which has eight. All have the same optical formula (derived from the CZJ Biotar 58/2), regardless of age or aperture design.
02-08-2013, 08:13 PM   #14
Now...to the OP...
The degree of Helios "swirlies" is highly variable, even within the same series and is dependent somewhat on choice of subject. For years, I swore that my 44M did not swirl; that is, until one day I got a swirly image. For example:
Wide Open...No Swirls!
Wide Open...Swirls!
Moderate Aperture...Definitely No Swirls!
...probably f/4.0 or so...
02-08-2013, 08:24 PM   #15
even at MFD
MFD? Do you mean minimum focus distance? I can't see that would make much difference. The most impressive display of Helios 44 swirl I have seen was a photo (posted on this site some years back) of a forest trail where the subject was some 5 meters distant. The whole leafy background was one giant swirl!!!
Take a "walk" through this group on Flickr and notice the number of photos with swirl. That should give you an idea of what is a reasonable expectation from the Helios 44 line.
http://www.flickr.com/groups/helios44/
bokeh, helios, k-mount, mfd, pentax lens, slr lens
Helios 44 userage Pentax SLR Lens Discussion 4 04-09-2012 08:39 AM
Decisions with Helios 44 vladimiroltean Pentax SLR Lens Discussion 9 03-23-2012 06:54 PM
Helios-44 F2. problem Hayob Pentax SLR Lens Discussion 8 11-23-2011 11:45 PM
Helios 44-2 (Гелиос-44-2) 58mm f2 preset 8 blades ducdao Pentax SLR Lens Discussion 5 04-25-2010 06:15 PM
What does the 44 stands for if anything, on the Helios 44-2? ismaelg Pentax SLR Lens Discussion 2 03-01-2010 02:05 AM
All times are GMT -7. The time now is 07:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
