08-29-2014, 05:04 PM   #1
Focus creep or defect?
I got my Pentax WR 18-135 ten months ago. I am aware of "focus creep" through reading the Forum, but am unsure what is normal and what is a lens defect.
A video of my lens concern can be found at
When pointing down, the lens is firm at 18mm. When nudged, it immediately goes to 70mm and stays there. When nudged again, it goes to 135mm
When pointing up, it is firm at 135mm but after a second or two slides by itself down to 18mm.
Is this normal and acceptable? Or should I send it in for repair or replacement?
Thank you
08-29-2014, 05:18 PM   #2
jatrax's Avatar
That is not 'focus creep'. Zoom creep is perhaps more accurate. Most zooms exhibit that to some degree some are really bad. My wife's 18-135 is not, maybe, as bad as that but it is close. I would say that is within normal parameters.
08-29-2014, 06:35 PM   #3
narual's Avatar
definitely normal.
If it bugs you, grab one of these: Stop Zoom Creep - LENS BAND
Or if you don't care what it looks like, a rubber band works, too. But the LensBands are only $5 and they look pretty nice. Plus they're handy to wrench off a filter that's misbehaving.
08-29-2014, 07:22 PM   #4
Senior Moderator
Parallax's Avatar
Moved to the proper forum.
08-29-2014, 07:36 PM - 1 Like   #5
crewl1's Avatar
Wait till you buy a Sigma xxx-500mm zoom and it does that.
Slam! The first time will scare you.
What you are seeing is normal for most consumer zooms.
( Why lensBand is in business. )
08-29-2014, 08:34 PM   #6
hcc
hcc's Avatar
I agree with others that it is zoom creep. There have been several threads about 'lensband-aids', incl.
https://www.pentaxforums.com/forums/6-pentax-dslr-discussion/161684-da18-250m...ion-works.html
However I would note that zoom creep is fairly rare among the DA18-135mm. In fact your thread is possibly the first one that I read (I could be wrong). I have myself the DA18-135mm and my 2.5 years old one has no creep. (MY DA18-250mm definitely has zoom creep!) If indeed this is rare, I would consider to call upon Pentax Warranty, unless you are happy with the len-band-aid solution.
My 5 cents....
08-30-2014, 09:41 AM - 1 Like   #7
Thank you all!
My practical education continues
135mm, 18mm, camera, dslr, firm, lens, photography, wr 18-135
Catch-in-Focus defect on K-x Marlboroman Pentax DSLR Discussion 16 03-09-2011 12:15 AM
K-x Autofocus ..... Defect or imagination ... Nightwings Pentax DSLR Discussion 28 08-07-2010 03:20 PM
Rack & Pinion Focus Creep dadipentak Pentax SLR Lens Discussion 15 11-05-2009 04:57 PM
AF-360FGZ defect or user error? Panache Pentax Camera and Field Accessories 21 11-05-2009 06:44 AM
All times are GMT -7. The time now is 09:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
