Yes - Boolean Query
Originally posted by cohny Don't forget that in most search engines you can use the - function.
For example if you could search "pentax XXmm FX.X -m -a" That particular search would return results with no m in the name and no a.
"(Asahi, Pentax) +(SMC,
xx,
xxmm) -(takumar, m42, screwmount, m, a, f, fa, da)" You can add SMC in the +operand but that doesn't exclude any of the later lenses. If you add SMC to the -operand you WILL exclude your K lenses.
You just have to wade through the return list by focal length. You can cut down the return list by adding common returns you want to exclude from your list - when you have what works, save your Search.
