09-23-2014, 07:00 PM   #1
Thoughts on what to do about broken 16-50/2.8?
Hello again!
I have a slight issue with my 16-50mm... I've buggered the electronics.
I took it apart to try to fix the SDM which stopped working, got curious, took it apart further (I had no idea what I was doing BTW) and when I got it back together, I noticed that it wasn't quite right.
Now, the optics are fine, but it isn't recognised by the camera (it asks for the focal length at startup) and the aperture wide open is reported as 5.6, but when stopped down to "6.3" the lens actually stops down to 6.3. And the manual focus ring needs to be pulled back to actually engage the focus mechanism.
I'm trying to decide what to do. I don't honestly use the lens much, even when it did work. I'm not sure if I'd want to pay for the full electronical overhaul it'd need. Should I just sell it as broken? Or what? Suggestions would be appreciated.
Thanks!
09-23-2014, 07:10 PM   #2
Sandy Hancock's Avatar
It's probably too late now, and it's easy to be wise in hindsight, but hacking the lens' EEPROM file to force the autofocus to operate by screw drive would have been a better solution.
I would be surprised if it would be worth selling in its current condition.
09-23-2014, 07:11 PM   #3
Andi Lo's Avatar
QuoteOriginally posted by SpartanD63 Quote
Hello again!
Thanks!
A bit late now but you should have done this... maybe try it and see if it does anything? https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/208353-how-...ml#post2203064
09-23-2014, 07:20 PM   #4
I considered that, but my cameras don't have debug mode (K-30 and K-01) And yeah, I doubt I'd get even $150 for it... hence the inability to decide.
09-23-2014, 09:12 PM   #5
I will give you 150 fore it!
09-23-2014, 09:26 PM   #6
QuoteOriginally posted by BCtoad Quote
At this point, if you're serious, and wouldn't mind paying to have it fixed up, shoot me a PM.
09-24-2014, 05:20 AM - 1 Like   #7
You realize that lens can be fixed for not much more really right? I don't know what enfield would charge, but CRIS would probably be in the ballpark of 2-300. A lot less than the cost of replacing it for sure. Sounds like it just needs reassembled properly. Seems like a waste to let a $1000 lens go for 150 when it can be repaired if you ask me. That's a significant loss of investment. Lenses are like new generally after a CLA/repair. I hate to be the voice of reason, but seriously, send it in and get it fixed by a trained professional.
09-24-2014, 05:22 AM - 1 Like   #8
I'm with him ^
Seriously.
09-24-2014, 08:24 AM   #9
The problem is, I don't exactly have the disposable income to get it fixed.I might keep ahold of it until I do then I suppose.
09-24-2014, 09:13 AM   #10
GlassJunkie's Avatar
I sent mine to CRIS Came back perfect....
QuoteOriginally posted by zosxavius Quote
SDM replaced, electronics perfect, calibrated, perfect, cleaned, 100% to spec $280.00 or so
09-24-2014, 09:29 AM   #11
QuoteOriginally posted by GlassJunkie Quote
I was expecting much more! Alright. I'll hold onto it for a while.
focus, k-mount, lens, pentax lens, slr lens
OUCH! Dilemma: 50mm broken, what to do? MJSfoto1956 Troubleshooting and Beginner Help 29 04-04-2014 06:04 AM
Pentax 16-50 DA* F2.8 and 50-135 DA* F2.8 - what's the best way to use them ? Foma2 Pentax SLR Lens Discussion 15 09-15-2013 01:23 AM
Broken DA* 50-135mm - what should I do? crimson_penguin Pentax SLR Lens Discussion 13 10-17-2012 10:21 PM
Having second thoughts about Sigma 17-50 2.8 Zafar Iqbal Pentax SLR Lens Discussion 21 12-07-2011 05:38 PM
What to do about 16-50? ksignorini Pentax SLR Lens Discussion 10 04-13-2008 10:29 AM
All times are GMT -7. The time now is 03:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
