Some of you may remember that I was waiting for a
SMC Pentax-DA 50-200mm F4-5.6 ED WR I ordered from Adorama during Black Friday which UPS had lost. Well it arrived Monday evening, and Tuesday (yesterday) I finally had a chance to take it out for a test ride.
Before we get started, let me tell you that my experience with longer lenses is very limited; I used to own the
SMC Pentax-DA 55-300mm F4-5.8 ED, and currently have a
Tamron AF (IF) 28-105mm F4-5.6, neither of which impressed me. I have since got rid of the DA 55-300, but I've held on to the Tamron because I scored it for only 30USD, so it's no loss. Also, I just never use longer focal lengths. So knowing this sparse background of mine, take my opinions with a grain of salt.
First the bad: This lens can be soft. The longer the focal length and the larger the aperture, the softer the final image. This is to be expected from this class of telephoto lens. But what did take me by surprise is how sharply [inverse pun?] the sharpness falls as you leave the center. At 200/5.6, the center is slightly fuzzy, but the borders are just ugly--unusable for prints larger than 4x6.
Also, while this lens has fabulous color contrast, it lacks micro contrast. Images have great tones, but they lack the pop I've come to expect from using primes. I find this particularly troubling with highlights. For a lens at least partially marketed for nature/outdoor scenes, it does not handle bright skies well. I'm not sure if this is a consequence of the coating or the optical formula.
I know this makes the lens sound poor, but I start with the bad for a reason: I want you to leave this post feeling the astonishment I feel.
Did I say this lens was soft? I lied. It is sharp! It can be soft if you press it. From 50mm to 135mm it is sharp at any aperture, and gets sharper as you stop down. Above that it is sharp from f8. At 200/11 it is sharp from the center to the far edges, only getting soft at the corners.
The colors are breathtaking, especially the magentas. This is a lens for Bryce Canyon. It handles reds and magentas better than my limiteds. Greens are deep and saturated, and only blues suffer a little (but are recoverable).
Distortion is surprisingly low. I'm not sure what I was expecting for a 4x zoom, but it has very low barrel and a pleasing amount of pincushion (I usually prefer a little pinch in the center). I honestly find it hard to see any distortion until I hit the lens correction.
But what I enjoy mostly about this lens is the build quality! My only other weather sealed lens is the
SMC Pentax-DA L 18-55mm F3.5-5.6 AL WR, so maybe I just have low standards when it comes to build. The plastic feels very high quality and the texture matches my K-5IIs and grip--not to mention balancing well--and the dampening of the zoom ring feels so good for a budget zoom! But what I love most of all is the Quick Shift! The focus ring is so smooth for an autofocus budget zoom! And I use it!
But enough of my rambling. Here are some images from my first outing with the lens.
