Originally posted by csa For now, the TC would be used with the Tokina 400 AT-X SD.
Not familiar with that lens, but - having had a quick look at the PF review - I suspect it is a screw-drive lens. As such, any TC with screw-drive capability
should work with it,
but the Sigma might not because its protruding front element might foul the rear element of the main lens.
OTOH, whilst a particular combo may physically work, the optical compatibility may or may not be very good as some TCs (e.g. the Sigmas) are only designed to be used with a particular manufacturer's lenses - and even then the lenses with which they work well may not include every one in that manufacturer's range.
Others may be able to provide more specific info on TCs for use with this lens.
---------- Post added 01-12-15 at 07:03 PM ----------
Originally posted by jeallen01 Definitely don't go beyond 1.4x - get a Tamron/Kenko (whatever - look at the PF converter tests for other brand-names for same item!) - as the K-10 has relatively poor low light autofocus.
Carol
Look in this part of the forum:
Miscellaneous Lenses for Pentax: Teleconverters (All Brands) - Pentax Lens Review Database
