Originally posted by Flugelbinder The 35 is 'only' 2.4 and has to be stopped down... One needs all the light one can get; and then there's the bokeh, and the DOF...
If you think the DA35 f/2.4 need to be stopped down to give good picture this is simple... No lense under f/4 will ever satisfy you. DA35 is simple one of the lenses with the best results wide open. I own FA50 f/1.4 that is very similar in rendering to FA50 f/1.7 and F50 or DA50. It really need at least f/4. f/2.8 is okish but far inferior to DA35 @f/2.4. My DA50-135, FA77 and DA35 plastic wonder all render far better at f/2.8 than the FA50 this guy does. And the DA35 & FA77 are the 2 that manage this apperture best.
As for the deph of field, either you need to be near to the subject (for an headshot for example) or you will have dof. That's not bad because it allow you to get scenes in low light at f/2.4... Something you couldn't do with a longer length like FA50 or FA77. But for sure if your are after shallow deph of field, 35mm f/2.4 is not going to do it... 35mm f/1.4 might do it but a longer focal is likely easier.
Here is a typical DA35 in low light, at f/2.4. Look at theses carefully to see "how bad it is"... And well go to dof master. f/1.4 would give just half the deph of field. So look at the picture. It is sharp everywhere, all in focus. Even f/1.4 would have done no wonder for a shallow deph of field effect. That was the intent... Because here we want everything in focus. But it just to make you understand.
DA35, f/2.4, 1/50, 1250 isos
and here another one:
DA35, f/2.4, 1/60, 800 isos
I hope everybody notice how bad quality id and how much I did need to boost the isos !
Also one day, I took a landscape and forgot to change the apperture. With most lenses this would go with so-so results. Not DA35:
DA35 f/3.2 iso 100, 1/4000
Honestly, if you thing the DA35 @f2.4 need to be stopped down... You'll not find a lense that is really better overall than this one at this apperture. This one is one of the few that is already sharp in the corners and contrasty at f/2.4. Man ! If my FA50 did perform that well at f/2.4 I would have never brougth the FA77 !
As for dof, large apperture like f/2 or wider it will work for putting a single subject in focus. For portraiture for example. Eyes in focus, nose not in focus. if you like that, that perfect and it work well for some kind of portraiture. Not for graphical or masculine one but at least for some dreamy feminine one. But as soon as you'll want to take a scene or a with 2 persons in the picture you'll need to stop down to have the subjects sharp. And that come more at f/5.6 setting anyway than f/2.4.
