Hi Everyone,
I just bought a used 16-50 off amazon and have noticed some strange things about the lens which I wanted to check were "normal" as I know this lens has its quirks.
1) Uneven sharpness across the frame at 16mm when set to Inf. Noticeable lack in the top left of the frame which is considerably worse than the opposite side.
2) Strange optics shift when the lens is manually moved to inf. It seems the frame actually shits as in some optical element is moving and it distorts the image and changes the frame fov by 1-2 degrees.
3) Noticeable wobble in the extending barrel worse than my 18-135.
I can still return it and probably will I just wanted to make sure I wasn't being too critical.
Thanks for your time.
Regards,
Chris
