The genuine m42 adapter works best and has high quality machining. I think its worth the extra cost. Made by Pentax, for Pentax.
On the other hand, some users report success with cheaper knock-off adapters. These usually need a tool to be removed (unlike the Pentax adapter, where a fingernail is enough). The real problem is if you get one that is poorly machined. There were cases where people had problems removing it from the camera.
Also, if you buy third party adapter, some have a flange or collar. This can be problematic as it prevents many lenses from reaching infinity focus. Unless you know what you are doing and want the collar/flange, stay away from these
Originally posted by lotech the contrast reduced considerably when stopping down, and the focus seems to shifted, I expected to get a clearer sharper image but I can't even get sharp focus after stop down to f8 and beyond, but physically the lens is in near mint condition the glasses are clear and clean, any comment ?
This is not normal behaviour. Most lenses are best stopped down one or two stops. Around f8 they have the widest DoF before diffraction starts to make the image fuzzy. If you make the photo with f16, it will not be very sharp due to diffraction, but that shouldn't affect contrast much.
Its difficult to say why you are experiencing your problem without a methodological test, with well-labelled test photos and controlled variables. I suspect the problem might be shiny aperture blades. Some older lenses are known to have metal aperture blades, sometimes with oil on them, so light reflects off of the back the lens and sensor, back to the aperture blades, and back onto the sensor. This can cause some odd flares and overall loss of contrast. Not much you can do about this other than adding a polarizing filter and a tight lens hood to minimize incoming light. A tight lens hood is a good idea for older lenses anyway, because they have (compared to modern lenses) poor lens coatings, so they cannot resist flare, ghosting as well.
Originally posted by lotech I have successfully converted a Leica Summicron into K mount with infinity focusing but that's another story.
Wow, sounds good!
