Did a test of the DA*300 and Bigma on both K-3 and K-5iiS to see which combo would be better for BIF.
(**EDIT- user audiobomber has suggested that the camera settings were not optimized for BIF and I agree. This test will need re validation which I will do as soon as possible and update. See his comments below. )
When I was done, I got the most in-focus shots with the K-3+Bigma.
First thing I found out is I need to practice this type of shooting if I want to get usable results.
The majority of birds flying were terns, and it was a very windy day so their flight was erratic except when in hover. Other birds that showed up - gulls, egrets, sparrows and a falcon.
I used TAv with shutter speed of 1/1000, and aperture f8 for the Bigma and f6.3 for the DA*300. No shake reduction or OS was used.
Use of faster shutter and OS/SR will have to be tested at some other point. Also, different settings on the K-3 such as 'hold' could have changed the results, in tjis case 'hold' was off.
AF was the main point of this test and after the exercise I would rate the AF performance for BIF combos in this order.
1. K-3 w Sigma 50-500 (AF Best, IQ Good if kept under 500)
2. K-5iiS w DA*300 (AF Very Good, IQ Best)
3. K-3 w DA*300 (AF Good, IQ Best )
4. K-5iiS w Sigma 50-500 (AF Good, IQ Good if kept under 500)
From an IQ perspective the Bigma did fine if kept at 400mm or less in most cases, the the DA*300 delivering best IQ
The K-3 and 50-500 combo did the best job of keeping BIFs in focus.
I used AFc, 9 point auto and the close positioning of the AF points kept the bird in focus even when it was not centered in the frame. It did a good job of staying with the bird even when it dipped below the skyline where backgrounds confused the other body. Zooming out to get the bird in range and then zooming in while shooting was usable. The lens quickly reacquired when it lost focus, without racking end to end. This combo resulted in the highest percentage of in focus shots.
The K-5iiS with DA*300 performed well. I used AFc with the 'auto' point selection switch. This worked excellent for when the bird was in the sky with nothing to disturb the AF, but would lose the bird and focus on the background if it dipped below the horizon. I tried single point but if you did not keep the bird centered it would focus out, but did come back quickly when the bird was in the center again. The Auto spot seemed best on this day as the birds were in clear sky most of the time.
I noticed that the K-5iiS seemed well matched to the SDM performance of the DA*300, as it responded to each AF change request positively.
I got a high percentage of in sky focused shots.
The K-3 and DA*300 in contrast did not do as well as the two above combos, it had more instances of going out of focus and not coming back, almost as if the commands from the K-3 were too fast for it to interpret. If the birds were on a steady path it did fine, but if it changed directions much the DA*300 did not seem to keep up. This combo seemed to always focus inwards when I first tried to acquire a bird that was not already in focus so it would lose some time.
The K-5iiS and 50-500 did OK, where the zoom helped to locate the bird but it seemed to lose focus more easily than the DA*300 did. It would come back quickly enough, but did not track as well as when it was on the K-3. Percentage of in focus shots was similar to the K-3 with DA*300. I would have expected it to do better as it performed best on the K-3.
At the end I added the HD1.4x to the K-5iiS/DA*300 and it performed similarly to the combo without the HD, but I did not test it very much.
Also noted: *Sigma 50-500 lens is heavy and hand holding becomes a chore after a while.
*The DA*300 light weight is well balanced on either K body so it is a pleasure to use for hand holding.
Here are some of the better samples.
K5iiS+DA*300
K-3+Bigma
K-5iiS+HD1.4+DA*300
Reason: Cameras not optimized for BIF
