Originally posted by pathdoc Why is it that all the ultra-fast lenses (f/1.2 or wider) seem to hover around the 50-55mm mark? (Let's talk in film terms to keep things easy and forget APS-C for the moment; AFAIK there aren't any APS-C lenses of that speed for Pentax in any case.)
When I think about it, my logic goes like this. The aperture of a 50mm f/1.2 lens is 50/1.2 or 42mm, plus then we have to have additional diameter around that for the aperture blades to retract into and all the associated mechanisms, aperture ring, etc. etc. Surely if we have a 42mm lens, we could either make the f/1.2 lens smaller or - going to extremes - fit an f/1.0 lens inside the same basic diameter? Going further, would it not be possible to make even shorter focal lengths even more extreme in aperture terms? What are the limitations that prevent this from happening? Why haven't we, for example, got 24mm f/0.5 lenses all over the place?
There are multiple reasons.
The most important one is flange distance. For most DSLR cameras, the flange distance is in the order of 50mm. That's no coincidence.
That means you don't need any complicated retrofocus design for lenses around that mark, which makes it much easier to construct fast "normal" lenses for a resaonable price.
That's also one reason why APS-C sucks, - the lens sweet spot is no longer a "normal" focal length.
Fast longer focal lengths are not so complicated to build since shortening the optical path is quite straightforward. However, the longer the lens the bigger the entrance pupil needs to be for a certain aperture. You need more glass which makes everything more expensive. More expensive means smaller market, so you're naturally seeing less of them.
But that's not everything. Larger diameter glass also means thicker lenses. If you look at some super fast designs you'll notice some very thick elements. At some point when their elements become too big, optical designs just break. You could counter that by using materials with higher refractive index, but there are only so many kinds of transparent materials. So unless we use fresnel lenses, cardioptic designs or infinitely dense glass, there are some physical upper limits on lens speed for telephoto lenses with refractive designs.
Side note: If you use cardioptic designs, these limitations do not appear. You can get affordable mirror lenses way faster than f/0.5 which you call "telescopes"
For wide angle lenses, it's more complicated.
Again, the market dictates what is developed. Few people really need fast wide angle lenses as they are mostly used for landscape which you need high DOF for. So, producing a fast wide can backfire if people aren't willing to pay the premium.
The physical limitation is the need for a retrofocus group to get the nominal focal length extended to the flange distance. Technically, that group is just an inverted telephoto lens. However, if you have a sensor larger than the entrance pupil, this becomes super hard to design in a fashion that still yields acceptable image quality.The reason is simply that you need very high refracion to both "extend" a focal point to like 5 times it's focal distance and still be able to reach the sensor corners from an entrance pupil much smaller than the sensor.
However, if the sensor is small in relation to the entrance pupil or you have a shorter flange distance, you can also have fairly fast wide angle lenses. For example, look at the leica lenses. Their register distance is around 20mm (if I'm not mistaken) since they are used on rangefinder cameras and you can have designs that are very fast (f/1.4 ish) around that focal length. I also have c-mount lenses at home that are 17mm/0.95 and 25mm/0.95 - Register distance is 17mm and image circle is like 1", so the designs are super simple (look like a gauss doublet to me). For that flange distance and image circle, you can even get affordable lenses as fast as f/0.7. However due to the crop factor, they are technically speaking no wide angles.
