Originally posted by Adam Yup the diaphragm must be set to manual as the camera cannot stop the lens down on its own. Since the viewfinder darkens, you can actually use Av mode without any issues also.
Either defective nor not installed properly. Did you mount the adapter on the camera before attaching the lens?
Yes, Adam, I mounted the adapter on the camera. I read an old thread here just a minute ago and I noted that there should be a locking spring on the adapter. My copy does not have any spring at all, so there lies the problem. Thank you for your help.
---------- Post added 09-01-2015 at 08:07 PM ----------
Originally posted by Not a Number If you bought the adapter second hand one of the previous owners may have removed the spring on purpose. Some people do this and attach the ring semi-permanently with a thread locker on lens they use quite often. Or the spring may have broken and was removed for that reason. Contact the person you bought it from and see if they still have the spring and retaining screw.
If you bought it new it should have a spring on it near the red dot. If it doesn't see if you can return it for a replacement.
I contacted the seller just now. Thanks for your help.
