Originally posted by cali92rs You could also get a used Tamron 70-200 f2.8. It is a pretty big step up optically from the 55-300mm.
It is usually a couple hundred bucks cheaper than the 60-250mm. The downside of the 70-200mm is that it is a lot bigger than the 55-300mm (it is about the same size as the 60-250mm). It is also pretty slow focusing. But then again, the 60-250mm is no speed demon itself.
I agree the Tamron is worth a look. Although it does not go to 300, its really sharp (mines particularly good 100 - 200) which at least gives you some cropping potential or potential to work well with a good 1.4X adaptor.
You might find one second hand. I don't find mine to be slow focussing and, while I have not tried to measure it, it seems faster than my DAL 55 - 300. I like the results from mine.
On the flip side, it is big, somewhat heavy (but appropriate for its size), AF on many copies does not work in LV (including mine), its not WR and it will probably cost more than you probably want to spend
