09-04-2015, 07:45 AM   #1
Help! bad hook.
(sorry for my english)
Yesterday i bought Mirage lens 28MM f2.8 (k mount).
When i try to hook at my pentax k-50, It does not engage well. It snaps in half and then not go forward, it blocks.
Here are some photos:
http://s13.postimg.org/n8jobdnw7/IMGP0381.jpg
http://s12.postimg.org/gafs97eh9/IMGP0383.jpg
http://s13.postimg.org/tq2kuvy9j/IMGP0387.jpg
http://s11.postimg.org/mthq2vvz7/IMGP0388.jpg
09-04-2015, 08:44 AM   #2
PentaxJax's Avatar
In the last picture It looks like the Ricoh pin?? 180 from the red alignment dot. Are you sure it is a K-mount? This pin needs to be removed to use on Pentax DSLRs.
Not all that sure as i don't have any with the pin, but a google search shows that location.
09-04-2015, 09:52 AM   #3
Oldbayrunner's Avatar
If it is a Ricoh pin it looks to me like the larger rounded spring type that doesn't really need to be removed.
09-04-2015, 09:57 AM   #4
The pin ISNT the problem at all on this lens as the Pin only prevents the lens from being removed after it is mounted........ I have the same exact lens and mine mounts somewhat tight but not sure why yours wont ?
09-04-2015, 10:28 AM   #5
so I have to remove the matte baffle or ricoh ping ? or both? (I have not understood what the matte baffle is)
if you can serve i can load more photos
09-04-2015, 10:44 AM   #6
UncleVanya's Avatar
QuoteOriginally posted by canny891 Quote
The baffle is the metal "shield" that looks like a shark fin beside the rectangle sticking out of the back of the lens. The rectangle operates the aperture blades. The shields of some lenses can be too large and run into things inside the open space behind the mount ring in the camera body. However another user has mentioned that they do not have any problem mounting the same lens on their camera.
The ricoh pin is a pin on some Ricoh k mount lenses that can get stuck in the screw that drives the lens focusing on autofocus lenes without an internal motor. The pin seen on this lens appears fairly rounded and is not likely a problem but could be removed to be sure that the lens doesn't get stuck ON the mount. That pin has nothing to do with not being able to mount the lens.
09-04-2015, 11:24 AM   #7
there is a guide for remove the baffle? thanks all
k-mount, pentax lens, slr lens
Prime Hook Sunset Imp Monthly Photo Contests 5 06-06-2015 02:06 PM
Abstract Hook for Dogs flaviopetrone Post Your Photos! 13 11-26-2014 09:25 AM
Black & White Sandy Hook Lighthouse reed_page Post Your Photos! 5 04-16-2014 05:04 PM
Abstract Ferry hook comprock Photo Critique 3 01-30-2014 12:53 PM
Macro Hook Michael Piziak Post Your Photos! 2 01-10-2014 06:20 AM
All times are GMT -7. The time now is 07:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
