Originally posted by falconeye Barry, thank you very much for your tests.
It contains many useful information. Btw, I do agree to your conclusion about the 60-250. Moreover, I think it is an example why I think corner sharpness matters more than vignetting. Vignetting, if not 100%, can be cured in post to some degree.
Half of what I published duplicated what others had done. (I wanted to check for myself!)
However, I think my tests using a 1.4x Teleconverter may be an important extension to this topic. I couldn't find such tests elsewhere. (Perhaps they exist but I missed them?) I wanted to know what would happen, because I'm sure that if Pentax supply such a Teleconverter I will buy it, and if Pentax supply an FF camera I will often use that Teleconverter with that camera, especially for the longer lenses. That means especially with my DA* 60-250mm f/4 and my DA* 300mm f/4.
If Pentax launched a 420mm f/5.6 lens, we would want to know if it was an FF lens. But that is what we get with a 1.4x Teleconverter plus a 300mm f/4 lens. And the 60-250mm becomes an 84-350mm f/5.6 lens, which sounds like a very useful lens on an FF camera.
A 1.4x Teleconverter works by expanding the image circle. If it expands the whole image circle, rather than just the centre of it, it "uncrops" the lens by the corresponding amount. A lens that was originally a 1.5-crop lens should become about a 1.1-crop lens. A lens that was nearly an FF lens should become a full FF lens. I think the above 85-350mm f/5.6 (60-250mm plus Teleconverter) will be a useful FF lens. Perhaps still a bit soft in the corners at 60mm (now 85mm), but good at longer lengths.
I suspect that if Pentax supply an FF camera, their 1.4x Teleconverter (if any) will play a role in many people's decisions. Perhaps Pentax themselves will promote it. (And I would like to know how the DA* 50-135mm f/2.8, which I don't have, behaves with a 1.4x Teleconverter. Will it be anything like an FF lens?) Unfortunately, Teleconverters tend not to work so well at wider focal lengths, so this will not be a general solution across all lenses.
