04-30-2016, 04:52 PM   #1
Protecting 15-30 front element
I'm always using B+W glass protectors on my lenses, but 15-30 is the first I got with the front element so bulging a filter seems irrelevant. The hood certainly protects a lot, but how do you feel walking around me with this thing?
A+
04-30-2016, 05:09 PM   #2
Sandy Hancock's Avatar
Front elements are tougher than most people think.
Keep the front cap on when you are not shooting and you'll be fine.
04-30-2016, 05:29 PM   #3
Na Horuk's Avatar
Front elements are tougher than most people think. Keep the front cap on when you are not shooting and you'll be fine.
Yep. And mount the lens hood when the cap is off (this is a great idea with WA and UWA lenses anyway). Oh, and be a bit careful with it, of course. Point it downwards when walking around.
The DFA 15-30mm doesn't even have filter threads, so unless you want to set up filter holders and then a square filter.. well, your hands are tied. Many UWA lenses are like that, though.
04-30-2016, 05:51 PM   #4
Once I left hobby mode and moved into much more expensive medium & large format gear with the goal of optimum performance and shooting for commercial use- I completely abandoned using lens filters for protection purposes and never went back. Just one opinion in a sea of thousands who practice the contrary.
The point is don't panic- especially if the lens design doesn't let you do anything differently anyways. You'll get used to it, and eventually you may even learn to appreciate it (less ghosting, less loss of color due to flare, greater contrast and resolution).
04-30-2016, 06:50 PM   #5
jatrax's Avatar
QuoteOriginally posted by braver Quote
I never use protection filters but I can understand the logic. And on older film era lenses they made a lot of sense, a good UV filter helped cut UV light and also protected the front element of lenses whose coatings were not all that tough and often got scratched. Modern coatings however are incredibly tough and largely eliminate the need for 'protection' filters.
However, the 15-30 leaves you no choice as it has no filter threads anyway. My personal philosophy is: lens cap always on unless in use, and if the lens cap is off the hood is on. Whether you use filters on your other lenses or not I guess that's the only choice on the 15-30.
05-01-2016, 01:37 AM   #6
PEG Moderator
Kerrowdown's Avatar
I don't use filters for protection on any lens, hoods work just fine for me.
On the “Mistress" (SMC Pentax-A 15mm F3.5)... well she's a bit more vulnerable, so I'm just more careful in handling her.
05-01-2016, 02:42 AM   #7
A+
I just think you need to get braver...
(sorry just a little joke on you Pentax Forum user name).
I have gotten away from using UV filters as protection. Most of the time a hood will protect any time a UV filter would have and doesn't have the downside of increasing flare (which a lot of UV filters do).
05-01-2016, 02:57 AM   #8
newmikey's Avatar
Never in 35+ years used either UV or "protection" filters. If God would have wanted the front element to be protected, He would have created an eyelid over the lens!
element, front, k-mount, pentax lens, slr lens
Macro 35-80 Pentax-F front element removed macro hack testing markoneswift Post Your Photos! 14 08-10-2017 01:40 AM
Disassemble front element of zoom lens SMC DA 50-200mm WR phidias81 Troubleshooting and Beginner Help 13 04-15-2017 08:19 AM
Disassembling Takumar 35mm 3.5 front lens element jns Pentax SLR Lens Discussion 10 01-07-2017 05:13 AM
I took a knife to the front element of my lens! Albert Siegel Pentax SLR Lens Discussion 13 02-19-2016 01:34 AM
What is this blemish on da35 2.4 front element? house Pentax SLR Lens Discussion 2 11-26-2015 12:43 PM
All times are GMT -7. The time now is 06:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
