Originally posted by UncleVanya It is certainly true that you need a wider aperture to get the same depth of field as sensor sizes go down. The exact amount is debatable.
As I understand this, it is largely due to the fact that lenses of the same focal length are used for different purposes on different sensors. A 15mm on a q may have the same depth of field at the same distance as on a k-3, but the view will be totally different and if compared with the "equal" lens it will look as though the smaller sensor had increased depth of field.
This is correct. People put as much of their subject in the frame as possible. Let's use the FA31 and FA43 for comparison, putting the 31 on a crop body and the 43 on a full-frame. The FA31 has an equivalent FoV on APS-C as a 46mm lens on a full-frame camera. For the most part, the FA31 on APS-C and FA43 on FF will fill the frame in the same way given a certain distance-to-subject.
Depth of field and strength of background blur is dependent on a number of things:
1) Focal length
2) Distance to subject
3) Distance from subject to background
4) Aperture
The relevant values here are #1 and #2. #2 is constant because of the nearly equivalent FoVs here. But the FA43 is focused closer for its focal length than the FA31 is. As a result, the FA43 FF shot will have more and deeper blur because a longer focal length lens is used on it. This effect becomes more dramatic as you move up: an FA50 on crop and FA77 on FF will have nearly the same composition from a given vantage point but the FA77 will have much stronger blur because the focal length is much longer for the focus distance.
On crop, the FA77 doesn't produce the strength of blur it would on FF because you have to back up another 5 feet or so to get everything you want in the frame.
