Originally posted by delboy65 Surely it is the function of the camera to decide what point to focus on?
Yes, but..
Originally posted by TER-OR Of course, if the lens isn't calibrated to the camera correctly (or vice-versa) then it gets tricky. But yes, the sensors are all in the camera.
there! Some lenses are optimized for AF on modern DSLRs and are good at it. Some lenses are made for previous generations, so they are not quite as fast, even on a modern camera (has to do with focus throw, or motor strength). A lens can also have a low contrast, or super shallow DoF, all of which increases the chances of misfocusing.
So, while AF is a camera function, the lens is a part of it, and some lenses will consistently focus well, while some will consistently misfocus (can be fixed with AF adjustment), and some might misfocus randomly (usually lenses with very long focus throw or third party lenses). Lenses with very low f-number require more light to AF correctly. Lenses with very low contrast will also have a harder time with AF. The lens is an important factor. There are also problems with focus distance changing upon stopping down aperture, which is a problem with some lenses, but not all. Sometimes a specific lens will not work best with your specific camera. For example, two DA 50mm lenses might focus with different accuracy on your specific camera. This is because each lens and camera is built to some tolerances, and when tolerances are opposite, there may be problems. With photography, even 1mm difference can cause havoc
I also have this theory that Pentax lenses have special, optimized AF algorithm profiles in the camera, that allow Pentax cameras to do slightly faster AF with them. Third party lenses rely on universal AF algorithms ,which might not be as fast. I cannot prove this, but its a theory. The things mentioned earlier are less theoretical.
Edit: Basically, AF is not something to rely on. Its a function to learn. Once you learn how AF works with
your specific cameras and lenses, then you can use it to its optimum. Just like metering and other things.
What the person quoted in OP is saying is that they don't have as many AF problems with other lenses. This can be specific to their own camera and lens, or to a lens model.
