Originally posted by interested_observer Good Morning,
That is somewhat of a loaded question. Let me explain in a couple of ways.
- In the past - up to a few years ago, Pentax had an AF - autofocus technology called SDM - "Supersonic Drive Motor". This technology in particular in the 16-50 lens, had a repetitively high failure rate. As of several years ago, Pentax figured out what was wrong and fixed it on future lenses. They also came out with a new AF motor called CM - which never had a problem.
Other than the AF motors, you have electronics that report the lens' settings. Electronics within the lenses (that support electronic interfaces) are really pretty robust. The original K lens, and M lenses have no electronic reporting capability. Starting with the A lenses type, the lenses that report.....
- identify the lens - i.e., Pentax A 50mm
- identify the aperture the lens is set to - i.e., f5.6
- identify the focal length which will vary on a zoom lens - i.e., 50mm if it's a zoom lens, then it will report the focal length that you zoom in or out to.
- identify the focus range - This will not report precise focusing distances, but will report in bands - close, far, etc.
Thanks for the answer. I actually mean any Pentax compatible AF lens. It can be Sigma or any other brand.
Normally the result of an electronics issue is: lens stops reporting settings to the camera. In result of that the camera can't AF with that lens anymore. Also for the minimum F number could be shown a wrong value.
The problem with old lenses is that no one offers parts for them. So no repairing possible. As there are many old AF compatible lense for Pentax I'd like to get an idea how often it happens. I already know about two Sigma lenses with dead electronics.
That thread is kind of addition to a thread which I started before:
https://www.pentaxforums.com/forums/189-repairs-warranty-service/324002-penta...-protocol.html
I already have some ideas how to go further but I still wonder should I dig more and spent more time on that issue...
Thanks for reading
---------- Post added 06-25-16 at 02:52 PM ----------
Originally posted by Bruce Clark I can report only one instance.
Sigma 70-200mm APO EX HSM Macro. Lens was new demo stock. Initial fault after 6 months was that AF completely failed. Returned to CR Kennedy, the Australian Distributors, who repaired it under warranty. Shortly after the AF failed again but only for subjects over 30 metres distant. Close up it was fine. CR Kennedy determined a faulty cct board in the lens to be the culprit and replaced the entire lens with another unit. No further problems have been experienced by me with this lens or any other.
Thanks Bruce. In your case you got lucky because it has happened during the warranty period.
I don't have enough information for any conclusions but it seems that sigma have some weak points in their lens electronics or they just have sold more lenses than the other lens makers
