07-25-2016, 10:02 AM - 1 Like   #1
bdery's Avatar
DFA macro WR on K-1 : step-down ring as hood replacement
Hi,
many people know of the trick to use a 49-28mm step-down ring for the DFA 100mm macro WR, when used on APS-C. It creates a fully operational hood, more compact and effective than the original one.
It doesn't work so well with full frame. There is visible vignetting which is of course not surprising (no black corners, thankfully).
I was wondering if anyone tried a step-down ring with a larger diameter, to perform the same task on FF. It seems 49-37mm step down rings are fairly common, but I don't have any on hand to test. Would those work well, without causing vignetting?
07-25-2016, 10:30 AM   #2
Can't help with your specific question I'm afraid, but like the step down ring idea, but can't source one anywhere. Is there a single 49-28 ring, or do you stack two?
07-25-2016, 11:02 AM   #3
On full frame, the very effective hood (sized for 100mm FoV on FF) is the one supplied with the lens
07-25-2016, 01:06 PM   #4
jumbleview's Avatar
I have used 40mm limited lens hood on DFA macro WR for APC-C (Pentax K5ii). It has internal diameter 31.5. Worked for me well. Eventually I bought inexpensive aftermarket substitution and returned 40mm hood back to where it belongs. But I have no idea how that will work for full frame. The opening is just marginally wider compare to 49-28 step up ring.
07-25-2016, 01:10 PM   #5
bdery's Avatar
The hood is useless when focused close. It's cumbersome at all times, especially when reversed for carrying.
QuoteOriginally posted by JohnX Quote
When I bought mine, they were common, now I can't find them either. Nowadays, 49-37 seems to be the only one-step available. Stacking two would work, of course.
dfa, dfa macro wr, hood, k-1 step-down, k-mount, macro, pentax lens, slr lens, step-down, wr, wr on k-1
49 to 28mm step down adapter for SMC-D FA 100mm Macro WR? PALADIN85020 Pentax SLR Lens Discussion 6 11-22-2018 03:47 PM
Diglloyd reviews DA 35, DFA 50 and DFA 100 Macro lenses on the K-1 Matchete Pentax SLR Lens Discussion 19 06-09-2016 09:18 AM
step down ring or step up ring ? dh4412 Troubleshooting and Beginner Help 5 04-14-2012 04:39 AM
77mm CPL on DA 15mm step down ring Alex00 Pentax SLR Lens Discussion 3 05-15-2010 08:21 PM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 04:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
