Originally posted by Digitalis avoid ultrawide lenses with infrared, because not only hot spots you will also likely encounter some serious smearing due to the fact that IR wavelengths aren't as easily bent as visible light wavelengths are.
That's a pity, but understandably true...
So filter needs to fit on my 18-55 mm II kit lens and some fast A prime.
Are there hudge differences between IR filters and IR filters?
- Which type / brand should I get (best bang for the buck)?
I found a Dutch company that sell them (720 nm) NEW up 67 mm diameter from stock for less than 30 Euro's, including transport costs (they can also "make" bigger, but that takes time and at higher cost).
