Originally posted by walter Same here. I'd like to see pictures of the disassembly if you have any. The lens comparisons would be cool too.
Sorry guys, I did not take any pictures except the ones taken with the lens while adjusting the focus mechanism.
The hardest part was to put the aperture blades back, it was very frustrating and I was very close to give up. The thing is that the aperture blade mechanism sits between 2 metal plates in the shape of a ring, and one of them has a tiny spring which I did not want to take off as it seemed too hard to put back(it was not the usual spring attachment). This whole package (easily falling apart) I had to put back in the body part(kind of an aperture container
about 3-4cm deep and making sure the small spring goes through a tiny whole at the bottom of the container. So with the help of a thread I pulled the spring through the whole while in the same time using a plastic bottle top that holds the 2 ring shape plates (the one holding the blades) to slightly insert it in into the aperture blades container. Basically what I call blades container is the body part joining the back element group and the front element group and also contains the aperture related mechanism and springs.
Originally posted by k100d sweet, how much is the Voigt based on the Topcor? is it the exact same optical design?
Not sure how much, but all I know is that the design was modified by Cosina so it's not exactly the same.
Originally posted by Big Dave Voe,
Are you going to adapt the Topcor to fit a K-mount or shoot with a Topcon film slr? I know that it has a fairly small lens mount. This may help in adapting it for infinity focus. At 44.7mm you will have to remove some material from the mount area to get infinity on a Pentax. The Pentax regristration distance of 45.5mm is 0.8mm greater then Exacta/Topcon. It should make a great 57mm equivilent portrait lens.
Dave
Hi Dave,
I bought this lens for my Pentax K10D, and I don't have a Topcon SLR. I already modified a Re.Auto-Topcor 135mm f/3.5 and Re.Auto-Topcor 35mm f/2.8 for Pentax. No issues with focus to infinity.
Someone might suggest a better way but I adjusted the focusing by trial and error method. As with my other two Topcon lenses I had to modify (cut about 2-3 cm) the focus limiter spacer on one of helicoids to allow for bigger range of focusing. This way I did not have to shave part of the body holding the lens mount to allow focus to infinity.
BTW I find white lithium grease great for lens focusing mechanism. I have used it on about 4-5 lenses already. This thing makes my old soviet lenses focus like Takumars, really smooth and dampened. The best part is that it does not leak when/if the lens is exposed to hot weather environment.
