You want more contrast? Find a higher contrast scene. It looks like most the earth tones in that scene reproduce to or near a middle gray. And scanning you have to adjust the contrast curve either in the scanning software or afterwards in an image editor. So don't judge a film by "auto levels" in a scanning software.
But there is no one answer for more contrast. And, scene dependent, colored filters can help and using a developer like Rodinal can really bring out the grain and contrast. A red filter would certainly darken the green foliage and moss, for example.
When you push your film, you decrease your tonal scale as well. How much is film/developer/time dependent.
When you make wet prints and want more contrast, you can use filters on the enlarger to change the grade of multi-grade paper or use a higher grade paper for fixed grade paper. Again, you will be cutting down your tonal scale by crushing the blacks and whites.
T-max films are tabular grain films as apposed to cubic grain in old-school films such as 400TX and 320TXP. They yield slightly different results.
Reason: More info
