Originally posted by Jetsam1 Well, looks like my Veho is dead (can't get into it to clean) and so I am considering a better quality dedicated scanner. i have been reading about the Epson V550 and it seems good and relatively easy to keep dust free? I like the idea of ICE as well........ It's expensive (relatively) but as I may be shooting film more regularly the savings compared to lab scanning should cover the initial costs. I do have a large box of my Grandad's and Dad's slides and negatives which I wouldn't mind re-scanning at a much higher resolution plus the ICE would really help some of the older slides.
So anyone with experience of home scanning? Is it worth not bothering with the Epson software and using Vuescan as I've seen recommended? Anything I should really know before committing?
Cheers!
+1 for the Epson V550.
I'm a long time Epson scanner user (older models and used mostly in graphic design workflow) - and in my experience they are the most affordable - very good quality - scanners around. I have scanned mostly photos and prints with the V550, and I can recommend it. I also scanned and enlarged a couple of slides (both 35mm and 6x6) - and I liked the result. The ICE technology is good, but it is not a wonder - you won't escape from retouching - but it does a decent work. I don't have anything against the bundled software - in the professional mode you can set up everything you need for a usual workflow.
As for the Vuescan - I've been using it (a few years ago) with some older Minolta film scanner - and I liked it - but until this point I didn't feel the need to buy it for the Epson V550.
Whichever solution you choose - you have to know, that scanning old slides or negatives is a time consuming task, especially the post-production :/
I have read - probably on this form (will try to find it for you) - about someone transforming an old slide projector - in combination with his camera - into a "scanning" device - with very good results - for digitizing old slides and negatives...
---------- Post added 05-05-15 at 13:19 ----------
This is something close to what I was referring to (still searching for the original post):
The other way to scan positive slides, or, why I kept my big DSLR by Stefan Schmidt | STEVE HUFF PHOTOS
