07-26-2014, 04:12 AM   #1
LW, reverse macro and internal flash. Flash fire issue
Hi,
I got a reversed lens on my K5IIs, internal flash poped up, shutter speed 180, single shot mode.
When i go with live-view trouble starts. As soon as i press the button half way it leaves LW and goes normal (viewfindermode), but when i press all the way down it fires the flash.
Is there some setting i messed up to make it like this? I want it to fire the flash and not change "view modes" (alot can happend i macro during that short time)
07-26-2014, 03:48 PM   #2
MarkJerling's Avatar
Could the reversed lens adapter be causing a short circuit issue with the body contacts?
07-26-2014, 04:37 PM   #3
If nothing is short cutted, the body will assume there is no lens attached. Is the reverse adapter anodized?
I don't have LV, but what happens if you do the same order of things without a lens attached?
I don't think LV should work without a lens, and whether the flash would fire may depend on a lot of flash related settings, and even be different for Pentax DSLR models.
07-27-2014, 05:57 AM   #4
Not a Number's Avatar
Aside from this problem if the subject is too close the built-in flash is likely to not even illuminate the subject. A popular Do-It-Yourself solution is to construct a "snoot" or tube to direct the light from downwards from the flash towards the subject. Search on subjects such as "DIY Macro Flash" for ideas.
09-04-2014, 07:23 AM   #5
Yep, already have one of those. Tissue paper folded is enough to spread the internal, not myself an alluminum covered ice cream box for the external. Both works like a charm!
camera, dslr, fire, flash, k-5, k-5 ii, k-5 iis, k5, lw, macro, pentax k-5, press
Viltrox JY670 ring flash - K5iis can only fire flash once, K7 is fine RobG Flashes, Lighting, and Studio 30 01-14-2018 03:43 AM
repair internal flash or buy an external flash Capslock118 Pentax DSLR Discussion 11 11-23-2011 05:22 PM
Internal flash as a flash assist goldenzebra Troubleshooting and Beginner Help 7 01-14-2010 07:14 AM
Can we set the internal flash of K-7 not to flash while connecting wireless with 360? raider Flashes, Lighting, and Studio 12 11-15-2009 09:31 AM
K10D - Noise - Internal Flash Issue rprii Pentax DSLR Discussion 4 12-20-2006 01:28 PM
All times are GMT -7. The time now is 09:11 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
