Just picked up a replacement K5iis, since mine got dropped and needs to go in for service to try to save it. I was putting this (used) replacement through its paces to test it, and I noticed that the EV meter bar in the viewfinder was not tracking the EV meter bar on the back LCD monitor. The one on the back (accurately?) moves into underexposure when I point the camera at a dark (large) area as you'd expect--and moves into overexposure when I point the camera at a bright (large) area as you'd expect. But meanwhile the one in the viewfinder does not follow its companion. In fact, the one in the viewfinder does not seem to move much at all. Correspondingly, the numerical readout of over/correct/underexposure in the far right of the viewfinder DOES seem to track dark and bright areas. So, it might read "-2.5" when the camera points to a dark area and the meter on the back shows serious underexposure--while the viewfinder EV meter bar just the left of the "-2.5" stays at its center point as if the scene was middle gray.
If there a setting in the menu that I have incorrectly set that could so disengage the viewfinder EV meter bar from the other metering readouts? Or is this a defect?
