Originally posted by 64t0 Hello, all.
I have been using a Pentax K5 II camera with its stock lens. The memory card is a 16GB Transcend SDHC Class 10 card. When I use Green Mode, the pictures record to the SD card in a short space of time. However, when using the other modes, such as Manual, Tv, etc., the recording always takes much longer. I have tried different types of Class 10 SDHC memory cards, but to no avail. I have also tried changing settings to match that of pictures recently taken in green mode, but the recording time is still too long - the hourglass lingers for several seconds instead of at most only 1 second.
Any input would be truly appreciated. Thank you.
Eduardo
Hi Eduardo, welcome to pentaxforums.
If the images are recorded, there is no mechanical problem. For me (on a k100d), changing to an older card worked once with the same issue. With this old card, I updated the camera and after that it worked with any card. Updating the camera might work for you, but if you decide to go down that road, be careful and patient.
