Originally posted by merengue Have been using it with 3 batteries for over a year and now the green led blinks with one of the 3 batteries discharged. Has anyone else had this happen? Checked on web and found nothing.
Thanks, Earl
Hello Earl, I had the same problem with one of my K-5 batteries. I cleaned the terminals with a Q-tip dipped in Surgical Spirit. For good measure I cleaned the charger contacts.
Eureka, the battery stsrted charging pretty fine.
I think some kind of an oxidized film builds up on the terminals over time.
Using a 9-volt battery to shock charge a bad cell is also a good idea. In fact you can use double the volts - in this case 15 volts - to shock the cell out of slumber.
Regards
