07-25-2014, 04:54 AM   #1
K5ii SD card problem
I have been reading some k5 SD card problems but no solving, and never find any issue with the K5ii.
Last Sunday I used my K5ii under a rainy day, worked perfect as spected, removed SD card to import them into computer as usual, and back into camera, but now 4 days later, trying to use my camera everything works perfect, it does not want to read any SD card. I have a k01 and tryed all SD cards and they works, so no problems with them.
I'm desperating, any idea.?
07-25-2014, 06:14 AM   #2
Closed Account
Rnovo's Avatar
...take the battery out, wait for 3 minutes or more and put another one in, fully charged...?
07-25-2014, 01:51 PM   #3
Done !! but no change, I stil get same error. . . I´m updaloding a video.
07-25-2014, 02:24 PM   #4
Otis Memorial Pentaxian
photolady95's Avatar
Did you try another SD card in the K5ll? What is the error message you get? Which brand is the SD card that's getting the error message and how old is it?
07-25-2014, 02:39 PM   #5
Here is the video !!
I used same cards in a pentax k01 and they works fine.
07-25-2014, 03:00 PM   #6
Mallee Boy's Avatar
Mystery. Have you tried re-setting the camera to factory defaults?
07-25-2014, 03:16 PM   #7
Yes !! Tried too, but does not work. And I have a wedding in 15 days.
07-25-2014, 04:27 PM   #8
I just watched the video and saw how you removed the card from the box you store them in. You touched the pins on the card, ugh! Fingers have oil on them, and it's not a good idea to touch them to your card/s pins. Try a pencil eraser on the pins, carefully run it across the pins, then use a brush to brush off the pins, and remove the rubbers debris.
07-25-2014, 10:36 PM   #9
altopiet's Avatar
Obviously the camera don't read the cards. As you've eliminated the cards as the problem, the problem should be with the camera. It's possible that the problem might be with the card contacts inside the camera, in your place I would try spraying the contacts with a little switch cleaner, one way or another the contacts might've gotten some dirt on them. You can't actually loose anything, because you'll probably have to send it in for repairs, if that doesn't work. I've used switch cleaner in the past on my K-x with sticky shutter button and lens release button, without any problem, and the K-x don't have weather sealing like the K-5...
07-26-2014, 06:48 AM   #10
Im worried about get some sprays inside card slot . Im thinking about a few days ago , I was trying to force a damaged card, with some plastic broken.
Maybe , any contact is twisted
07-26-2014, 03:21 PM   #11
PROBLEM FOUND !!!
A friend of mine, bring a k5iis for comparing sd card slot pins, and we found two pins missing, I think they was broked with that delkin card . . .
as seen in picture, fourth and sixth pin are missing.
camera, card, k5ii, k5ii sd card, pentax help, sd
optio S50 problem when I put in SD card carzey3 Troubleshooting and Beginner Help 2 06-09-2014 11:08 AM
For Sale - Sold: Pentax K-5 II * 32GB SD card * K5II REDUCED transam879 Sold Items 5 03-03-2014 09:26 PM
Problem Formating SD card X-Raycer Troubleshooting and Beginner Help 11 07-20-2013 12:33 PM
Problem with SD Card and *ist DL sailor1942 Troubleshooting and Beginner Help 3 03-25-2013 03:35 PM
SD Card Problem dogbear1980 Pentax DSLR Discussion 5 01-09-2010 05:29 PM
All times are GMT -7. The time now is 01:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
