Hi all,
I just noticed something odd in the LCD panel on the top of my K10. In the lower right quadrant I normally used to see the ISO setting. For some reason I have a number showing which seems unrelated to ISO. It is counting backwards from 827, one shot at a time as I trip the shutter. I have set the ISO to 100 and taken a few shots. The images are properly exposed and show ISO 100 in the EXIF but the 827 number returns and starts counting down again. I don't see anything in the K10 Operating Manual regarding this issue.
Here are the steps I've taken so far:
I have deleted all images on the card and reformatted it.
I removed the card and rebooted the camera. I turned it off, reinserted the card and turned it on again. It's the old turn it off and on again trick that often works with computers. No luck.
I have restored the original factory settings.
The battery is fully charged.
I have tried different settings: M, SV, TV, AV TAV, and P
I am running the most recent update for the K10.
Makes no difference whether I am using a DA lens or an old M series lens.
Makes no difference whether the camera is set to auto or manual.
Other than this glitch everything else seems normal. Any ideas or suggestions?
Thanks
Tom G
Reason: typo
