07-03-2011, 01:41 PM   #1
Bower flash wont sync in slave mode.
Hey guys, I bought a Bower SFD926P for my pentax k-x. It works fine when mounted on my camera, but when I use it as a wireless flash it wont sync 90% of the time. The flash fires all the time but will only sync 1 in 10 times randomly.
Is it because it is a cheap flash? (I can make my peace with that) or is there something I can do to correct this?
Thanks.
07-03-2011, 01:55 PM   #2
Disclaimer: I don't own and have never played with this flash unit.
I think the Bower SFD926P does not support Pentax p-TTL wireless flash, even though it does have a (dumb) optical slave function. In other words, in slave mode, it is triggered by any strobe.
Do this: set the Bower (off camera) in slave mode, set the camera in 2 second timer delay mode with the built-in flash up, try a test shot. You will see:
1. The preflash strobe from the built-in flash.
2. 2 second delay.
3. Mirror going up and the main strobe from the built-in flash.
Notice what the Bower is triggered by, (1) or (3). My feeling is it is trigger by (1), and probably also (3) depending on whether it recharges fast enough.
07-06-2011, 10:27 PM   #3
abmj's Avatar
I own that flash and have had the same problem. As you noted, it is fully p-TTL capable when on the camera. It appears that in slave mode, the flash triggers on the preflash from the built-in flash instead of waiting for the main flash. It goes off but not while the shutter is open. It is very disappointing but I guess you get what you pay for.
My best way so far to get this flash unit off-camera is to use a radio trigger. That means that I can't use the on-camera flash to add a second light source so instead I use a second off-camera flash with an optical slave trigger. The radio triggers the Bower flash and that triggers the other one.
08-23-2015, 09:16 AM   #4
I found a solution that works for me thanks to the information you guys have shared here. To try and stop the off camera flash from being triggered by the on-camera flash "pre-flash", I took some black nylon material and made a screen that wraps around the off camera flash, filtering where the red sensor is to block out the pre-flash. Now the off camera flash only responds to the "real flash" and contributes to the photo. Hope this is still of some use to someone.
bower, bower flash, flash, lighting, photo studio, strobist, sync, time
Anyone tried a bower flash in k-r ? Sekul Flashes, Lighting, and Studio 2 01-17-2011 10:20 AM
Slave 2 Mode x Auto Power Off BBear Pentax Camera and Field Accessories 15 07-14-2010 01:58 PM
popup flash wont stay closed blackcloudbrew Pentax DSLR Discussion 10 03-02-2010 08:35 AM
Can I run the Pentax AF-540 Flash in wireless optical slave mode ? Enc0der Flashes, Lighting, and Studio 4 12-12-2009 06:54 AM
slow speed sync in AV mode? quaker Pentax DSLR Discussion 19 11-15-2009 03:10 AM
All times are GMT -7. The time now is 12:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
