04-23-2014, 10:39 AM   #1
Class A's Avatar
Cactus V6 Radio Trigger has Arrived
The Cactus V6 has arrived.
A full review will follow very shortly.
EDIT: I've made the first draft of the review available for comment.
If you have a Pentax FGZ flash or any old film-style TTL flash, the V6 may be of high interest to you.
04-23-2014, 11:41 AM   #2
schnitzer79's Avatar
Nice. Do u think it will work with my old Nissin 280FX? lampu flash Nissin Electronic Flash 280FX | Kaskus - The Largest Indonesian Community
04-23-2014, 11:43 AM   #3
Looking forward to reading more about this much needed (for Pentax) product.
04-23-2014, 02:33 PM   #4
Class A's Avatar
QuoteOriginally posted by schnitzer79 Quote
It is rather likely that you'll be able to trigger the flash but in terms of remote power control this particular model may not fulfill the requirement of at least two manual levels.
04-23-2014, 02:34 PM   #5
Class A's Avatar
QuoteOriginally posted by DSims Quote
I agree that Canon/Nikon shooters had other alternatives already (not with the same level of brand independence, though), but for Pentaxians, this is rather significant.
04-23-2014, 08:00 PM   #6
@ClassA. The Cactus V6 has arrived.A full review will follow very shortly.
Look forward to that, especially anything about Pentax af280t compatibility..
04-24-2014, 04:05 AM   #7
Class A's Avatar
QuoteOriginally posted by bobD Quote
It looks like the Pentax AF280T natively only supports manual levels 1/1 and 1/12.
However, the Cactus V6 needs two natively supported manual levels below 1/1 for flash profiling purposes.
It looks like from the old Pentax range only the AF400T and the AF200T fulfil the requirements regarding manual levels.
P.S.: Almost done with the review.
04-24-2014, 06:30 AM   #8
Looking forward to the review. I hope that maybe you can describe the theory behind the flash profiling and the need for two or more manual fractional power levels. You've got me curious about the concept, but I can wait for the review -- no need to expend your efforts multiple times.
04-24-2014, 06:50 PM   #9
Class A's Avatar
QuoteOriginally posted by Tanzer Quote
I have just made the first draft of the review available for comment but I'm not sure whether it is answering your question in sufficient detail.
The Cactus V6 uses the so-called "quench"-pin of legacy TTL flashes to control their power output. The earlier the V6 "quenches" the flash, the lower the output. Quench times differ from flash model to flash model so if the model is unknown to the V6, it has to work out the correct quench times. It does it by measuring the output of reference levels (as many manual levels as your flash model can provide) and will then work out the quench times to reproduce these reference levels (and a lot more inbetween to enable finer-grained adjustments).
Two reference levels are the minimum required in order to work out the shape of the whole quench curve in order to support power level control from 1/128 up to 1/1.
I hope this answers your question.
P.S.: I didn't go into such technical explanations in the review because as a user you just need to follow some straightforward instruction displayed on the V6's LCD screen and the rest happens automatically.
04-25-2014, 07:54 PM - 1 Like   #10
And another flash that was newer than those in that list would be the AF 500FTZ. Electronic Flash Chart
04-25-2014, 08:31 PM   #11
Yes, you answered my question here, and the detailed review you posted is fantastic. It would still seem to me that the flash should somehow be able to learn the profile only by quenching at various intervals, but then again I'm sure this is not that simple. I need not second guess the developers.
04-26-2014, 08:51 AM   #12
Class A's Avatar
QuoteOriginally posted by jake14mw Quote
Thanks, that one should work as well.
It would be cool if people who get the V6 and have such flashes could confirm that they are actually compatible with the V6. As I wrote in the review, there is a good chance they will, but before anyone has tried it, it is not possible to say for sure.
04-26-2014, 08:53 AM   #13
Class A's Avatar
Thanks a lot!
It was a lot of work. I enjoyed sharing my enthusiasm for the V6, but it still was a lot of work so it is very nice to get some positive feedback.
It is indeed not simple.
EDIT: I thought about this some more and the reason is probably that the V6 sensor would have to function in an absolute manner rather than in a relative manner as it does right now.
05-02-2014, 06:16 PM   #14
Class A's Avatar
Meanwhile, I've come across a solution which involves ND filters.
If you have ND filters of strength 1-stop and 2-stops, for instance, you could simulate the manual power levels "1/2" and "1/4" by letting the fire flash at 1/1 power but holding the respective filters in front of the V6's sensor.
The next question is whether the flash will recycle quickly enough because the V6 allows increasingly less time for lower power levels in order to cut down on the whole profiling time...
05-02-2014, 07:59 PM   #15
I was thinking the same thing, but then I thought that during the learning mode, the sensor on the V6 was monitoring flash duration time, rather than intensity. Look forward to hearing your results.
I guess if that does work you could get similar results using black gaffer tape over 50% of the flash head. Kinda kludgy and maybe that would get too hot.
arrived, cactus, cactus v6, cactus v6 radio, camera, center, curve, filters, flash, flashes, level, levels, lighting, output, p-ttl, pentax, photo studio, pin, power, radio trigger, reference, shoot, strobist, v6
Cactus V5 radio flash trigger review Class A Flashes, Lighting, and Studio 274 01-22-2019 10:36 PM
Commlite Comtrig T-320 radio trigger bnorikane Flashes, Lighting, and Studio 7 02-27-2014 10:21 AM
For Sale - Sold: Flashwaves Digital Radio Flash Trigger Set stormtech Sold Items 3 02-25-2013 03:06 PM
For Sale - Sold: FlashWaves radio flash trigger set NeverSatisfied Sold Items 4 01-26-2013 09:15 AM
Pentax AF360 Flash and Radio Trigger ColinH Flashes, Lighting, and Studio 2 09-23-2012 10:47 PM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
