09-01-2014, 08:14 PM   #1
Guide number - useable light
A flash's guide number is given as 35 - 35 metres with ISO 100, 35mm. (I'm assuming that's a 35mm focal length lens.) Doubling the distance gives less than double the light at that distance unless the ISO is doubled too. Is that right?
What happens to the light? Is it always enough for a proper exposure at those calculated settings and distances? At what point does the light diminish to below a useable illumination? Because of the scale of diminishing returns it must happen rapidly when it happens.
09-01-2014, 08:34 PM   #2
The Inverse Square law applies, with only one quarter the light at twice the distance. This is why it fits so nicely into the F number calculation. The light becomes unusable when you can't open the lens aperture any wider.
09-02-2014, 04:52 AM   #3
Ole
Ole's Avatar
To add to the above response, the guide number changes with the focal length of the lens in use with such flash units that have a zoom head (provided that the flash actually zooms (or is manually zoomed) to match the focal length of the lens).
A flash will not zoom automatically with K, M and A series lenses.
09-02-2014, 06:18 AM   #4
Thanks for that. I think I got it.
35mm, distance, flash, guide, iso, light, lighting, photo studio, strobist
DA 40 Ltd.-how useable in low light/interior photography? planedriver Pentax SLR Lens Discussion 27 11-25-2016 02:33 AM
Flash guide number - trying to understand justtakingpics Flashes, Lighting, and Studio 6 04-04-2011 07:18 PM
Understanding Flash Guide number dosdan Flashes, Lighting, and Studio 8 10-17-2009 07:41 PM
Need flash manual or guide number hillerby Flashes, Lighting, and Studio 9 07-24-2009 11:55 PM
All times are GMT -7. The time now is 02:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
