Somewhere in late September last year I had my Metz 52 firing randomly by itself when in HSS mode. I contacted the Metz Germany and explain my problem. At that point they were unaware of the problem and after I reported this they responded back asking me on more details on the problem. I send another email with detailed info and settings used on Pentax K-3 and K-5II, lenses used, etc. Turns out that they did not have neither camera but they had K-7 and K-30 and was able to replicate the problem I had. I was reading here that some other users had the same problem and reported this to them as well. Finally in October they forwarded the issue to development department and informed me that they will notify me when they got problem fixed.
I thought first that this is it and I have to live with it... but no way, Metz did take this seriously and responded back on January 23 that they have fix for this and released new firmware which solves the problem. I guess tomorrow is update time, borrowed flash to a friend, after I pick up.
Kudos to Metz and with this they won me again back (using Metz since mid 90's), even I was short of pulling trigger on some other Pentax flash.
Here is the email I got with update link:
Dear Mr Lxxxx,
As of now a new firmware version (1.3) for the flash unit mecablitz 52 AF-1 digital for Pentax is available by which the mentioned problem is solved. This new firmware can be downloaded from our homepage by following link:
http://www.metz.de/en/flash-units/firmware-download-flash-units/mecablitz-52...al/pentax.html
Best regards
from Metz webpage:
Firmware 1.3 (released on 23.01.2015)
Improvements:
1. Sporadic triggering in P-TTL HSS mode by itself removed.
2. Triggering together with K-lenses in Rear function enabled (Attention: P-TTL isn't possible with K-lenses determined by the system).
3. P-TTL-flash-mode enhanced.
4. Zoom size function is automatically activated.
