Hi All,
I have the following equipment :
Pentax K-5 II Metz Mecablitz 50 AF-1 for Pentax flash unit Canon Speedlite 430EX II flash unit Canon Speedlite 90EX flash unit (no power control but hopefully can be used as hair light or background light) two flash mounted diffusers, DIY snoots (ex stubby holders) two tripods (one flimsy - still good enough for a flash unit, and a proper one).
I am really keen to try three point lighting, etc.
Can you please advise me on what else I need to get it working.
Pentax K-5 II and Metz 50 AF-1 work perfectly with both optical slave mode (no transmission) and wireless (optical transmission).
Unfortunately neither Canon 430EX II nor Canon 90EX do not have optical slave mode (no transmission) ("dumb" optical slave mode).
And as they are eTTL they cannot be used in wireless (optical transmission) mode either.
All I want to do is to make it work, so I do not want to spend a lot. Just bare minimum.
What do you think about this
Wireless Radio Slave Remote Flash Transceiver Trigger 3 Receiver 4 Channels | eBay
AU $28.59
The only issue I can see with this kit is that it won't sync faster than 1/125.
Or, do you think I should invest a bit more and get better/proper radio triggers ? If so, which ones would you recommend ?
Thank you
