Originally posted by pursang Thanks for your experience with the Cactus v6 as I had considered trying one, but based upon your experience I'll hold off.
I don't think there is reason to be discouraged.
There are a number of ways you can achieve HSS illumination with a V6. The variability of the delay value panoguy alluded to applies to two of them but only occurs when you change the aperture value and for the K-3 apparently is largely non-existent even then.
I refer to
two HSS techniques in my V6 review with one of them not needing a delay setting at all (but being limited in the maximum shutter speed).
Since then I came up with a
HSS technique that does not need a HSS-capable flash for triggering purposes.
The question in your case is whether you can manually set a Wistro to using HSS mode. If you can, you can use the same techniques that work with the RF60, but there is a chance that the Wistro depends on the Cells trigger to operate in HSS mode.
If you could not engage HSS mode on a Wistro manually, you would be left with the HyperSync technique only, i.e., you could do all of the above but the Wistro would have to run on full power output because only then its flash duration would be long enough to illuminate the whole frame.
