08-01-2015, 06:40 AM   #1
Simon TSI 224 flash with k-50?
I found this at a garage sale for next to nothing.
I would use it for macro work only with a diffuser.
Is it safe to try?
Thanks.
08-01-2015, 04:08 PM   #2
If in doubt, don't use it directly on the hot shoe, but use a pair of radio triggers to fire the flash (one on camera, one on flash). Or mount the flash on an optical slave trigger and fire it via the built-in flash. Or mount the flash on top of a safe-sync flash shoe.
The Cactus v6 trigger can do all of the above. It's a handy bit of kit.
08-01-2015, 05:55 PM   #3
Class A's Avatar
+1
If you have a voltmeter/multimeter you may measure the trigger voltage of the flash yourself. Pentax cameras should handle up to 30V.
08-01-2015, 10:06 PM   #4
If in doubt, don't use it directly on the hot shoe, but use a pair of radio triggers to fire the flash (one on camera, one on flash). .
Do check the specifications on radio triggers as some have limitations on maximum voltage too!
You will save the camera but may kill the trigger...
08-01-2015, 10:26 PM - 1 Like   #5
QuoteOriginally posted by bobD Quote
Triggers can be a lot cheaper than the camera - hence a worthy sacrifice.
I think the best solution for OP is simply buy a modern budget manual flash off eBay for example. Lots of cheap modern Chinese flashes will do the job for not much more $$ than an old thrift store flash. And no need to worry about flash voltages, or futz around with remote triggers etc.
08-01-2015, 10:37 PM   #6
+1
08-01-2015, 10:54 PM   #7
Class A's Avatar
Cactus V5/V6 take up to 300V.
And no need to ... futz around with remote triggers etc.
But how do you get your flash off-camera then?
08-01-2015, 11:18 PM   #8
Corrr! That's superb...!
---------- Post added 2nd Aug 2015 at 06:57 PM ----------
Optical trigger from the onboard flash ?
http://www.amazon.com/Seagull-Wireless-Remote-Trigger-Reduction/dp/B004HFV5PS
can be set to ignore preflash....
https://www.pentaxforums.com/forums/125-flashes-lighting-studio/187513-seagul...tructions.html
08-02-2015, 04:11 AM   #9
Class A's Avatar
Yeah, that's definitely a readily available solution, but rawr was aiming at avoiding to "futz around", and optical triggering is more challenging than radio triggering.
08-02-2015, 05:05 AM   #10
Easiest off-camera solution for close in work like macro is, of course, a hot-shoe flash cable. Very simple and reliable.
08-02-2015, 01:45 PM   #11
I agree, that is probably the best strategy.
08-02-2015, 01:54 PM   #12
grhazelton's Avatar
+1
I've read that digital volt/ohm meters are the way to go, rather than the analog sort with a needle indicator. Why, I don't know. Fortunately these can be bought for about $20 at Home Despot and other big box stores.
08-02-2015, 04:37 PM   #13
Class A's Avatar
QuoteOriginally posted by grhazelton Quote
If the input impedance -- essentially the internal resistance -- of the voltmeter is too low, it will measure a voltage that is lower than the original value.
Digital voltmeters all have very high input impedence and hence are always reliable. There are many analog meters that will do just fine for this purpose, but one should check their input impedence which should be at least 10MOhm.
08-02-2015, 04:44 PM   #14
grhazelton's Avatar
Thanks for the clarification!
flash, lighting, photo studio, strobist
K-50 with 18-55WR + 55-300 + AF-200FG Flash + Eye-Fi 4GB SDHC for $647 RonakG Pentax Price Watch 5 12-08-2014 03:08 PM
Pentax K-50 with 18-55 WR and 50-200 WR lenses, AF-200FG flash, and $50 Adorama gift TomTom Pentax Price Watch 4 05-09-2014 09:10 PM
Flash Photography with K-50 & SMC-M 50mm Lens Schmidt Pentax K-30 & K-50 7 12-03-2013 10:54 PM
Vanguard ALTA+ 224 Carbon Tripod SBH-50 PlumRT Pentax Price Watch 9 07-07-2013 10:33 AM
Pentax 50 1.8 now $224 @ B&H Docrwm Pentax Price Watch 5 08-22-2012 12:07 PM
All times are GMT -7. The time now is 04:32 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
