Originally posted by royden Thanks Belcik. I was just reading the Amazon listing for the 560 lll and saw where it will work on any camera with a hot shoe and I figured it would be manual only. Would I be better off with a unit that's TTL? Back in the 70's I had a Vivitar 283(I think) and had a lot of misses. But that was film. With digital I could shoot again and again. I'd appreciate your thoughts on manual vs TTL. With manual I could use the same flash on my Pentax and on my Canon.
---------- Post added 11-27-15 at 09:46 PM ----------
Thanks Tonytee, Feel free to chime in on my ? in previous post
Okay I decided to return to the drawing board. I set my Nikon SB-24 ISO 200, aperture at f/8 and zoom at 85 mm.
My Pentax K100D super Camera at ISO 200, shutter dial set at Autopict. From there I went into my light less living room, aimed the camera at a very dark spot, slowly pressed the shutter release. The flash fired as expected, however, the plot thickens here, the shutter speed was set at 4 and aperture at f/4 according to the info in the viewfinder, so what happened was, the shutter remained open for approximately 5 seconds after the flash did its job. Needless to say the photo was overexposed. I forgot to mention that the flash was set at the TTL position. So, again trying to manipulate the flash and camera to work the way I wanted them to, I reset everything back to manual and the pics came out just fine. Here is another thought. I believe that a serious photographer should stick to the dedicated devices that are manufactured for the express use of same brand equipment. Sure, it will cost more, but here is one consolation: Let's say you purchase new a Nikon SB-whatever flash unit and it malfunctions. You return it to Nikon and they cannot claim that the reason for the malfunction was because you used it on a camera it was not made to be used with. They will find any excuse to get out of warranty work. I know because my wife had that very same problem with Nikon. Speaking for myself, the SB-24 will stay with my Nikon Digital Camera. As for the Pentax, it has a very good onboard flash unit that I try not to use frequently because it has an insatiable appetite for batteries. Well, I hope this helps.
Rgds,
Tonytee
