Originally posted by mcgregni Some great points there nanhi, thanks, very interesting. Sounds like you're saying that module operates the flash as an 'auto-thristor' type ... ? The latest Tumax version with P-TTL and a digital interface looks very tempting at the price ... just seems to be distribution and availability which is a problem (eg I can't get the top model on Amazon UK at present).
Thanks mcgregni Sir. I wrote that post from my personal experience using a Quantaray QB-6550U Flash ($ 12 from Wolf Camera) + Quantaray Manual QDA-P Module ($10 on eBay).
I have the most power little flash like the Auto Thyristors of circa 1980. And OMG, it communicates with the Pentax K-5 IIs:-
"The flash reads the ISO setting from the camera and in Tv mode, it can then set the aperture on the camera appropriately. On the flash module is a slider with three coloured square – blue yellow & green. On the flash is an ISO slider with corresponding f-values and the maximum flash distance - again with the three color codes. For ISO 100, the blue setting calls for f2, yellow f4, and green f5.6.
Since everything communicates, changing the ISO settings changes the aperture. Example, say you have the FA 50mm f1.4 on the camera and have set ISO 100 to start at f4 - yellow. Raising the ISO on the camera to 200 means the flash sets the aperture on the lens to f5.6. Raising the ISO again to 400 mean the flash sets the aperture to f8, and ISO 1000 would get you f11. You could have set the flash to blue - f2. Raising the ISO to 200 would then set the aperture to f4, raising it further to ISO 400 would set the aperture to f5.6, and so on.
The other neat trick to this is that EV comp works in the same fashion. Setting ISO 100 at blue - f2 on the flash, and setting ISO 100 on the camera; to get f1.4 on the FA 50mm 1.4 means adding +1.5 to 2 EV. Bouncing with this flash with a normal 10 foot ceiling and not too wide a lens works really well. The small size and weight is really nice for this".
Note: 1) If I buy the Promaster 5050DXR Module ($40 to 50 on evil bay), I have the smallest most powerful PTTL Flash. But why bother, when Yongnuo sells the best PTTL Flash for $ 60.
Move out Pentax with your $ 400 to 300 flashes.
Sir the Yongnuo is the most popular and far better than the Tumax. Believe me I have an older Tumax version bought in Dubai.
The Quantaray / Promaster / Sakar / Digital Concepts etc. is made by the same one Manufacturer and re-badged.
Regards.
