Originally posted by kwb Hi timedriver, on my Q7, I can go up to +-3 EV in bracket mode.
To change the bracket spread, I have to:
Press drive mode (that's the right button on the four-way pad).
Use right-left key to select exposure bracketing ("+-" icon).
Press down key.
Use right-left key to select "Exposure Bracketing" or "Exposure Bracket + Remote CTRL".
Press down key. A graphics showing the control wheel is presented.
Use the control wheel to adjust the bracketing spread from +-0.3EV to +-3.0EV in 0.3EV steps.
When done adjusting, press OK.
Thanx, This old dog without his reading glass's missed that last step with the down button
Best,
kwb
---------- Post added 05-06-16 at 03:45 PM ----------
Originally posted by Adam You should be able to increase the spread. Do you see an option to do so when the press the down button after highlighting bracketing in the drive mode menu?
Thanx again Adam, I completely overlooked that very last step that KWB pointed out...I assumed that I was just going into remote mode without another option.
