12-26-2014, 10:50 AM   #1
Imp's Avatar
ACMAXX screen protector
this might be in the wrong place, but there wasn't a place to put it under accessories... so here it is
I just bought a ACMAXX hard screen protector for my K30, and applied it, and went out to shoot pics. However, I encountered a problem. If I pressed the screen protector, a bubble would appear. It looks somewhat oily.
Yes, I cleaned my lcd thoroughly before applying the protector.
The solution was to pry up one edge, and the bubble would disappear. Then I would press down the edge again to seal it. Now this isn't a good solution, because the screen will quickly deteriorate. What do you think is happening, and how could I fix it?
thanks
12-26-2014, 11:08 AM   #2
They will sometimes get that, especially in the time period after you first install it. It will go away, but may reappear with quick temperature changes, etc. It isn't a "problem" since the screen is hard, but may be a visible distraction. So what you do is ignore it. If it is going to drive you insane to ever see that, I'm afraid you'll have to choose a more flexible screen (but that offers less protection).
02-25-2015, 04:34 PM   #3
Imp
Imp's Avatar
It's been over a month now, hasn't disappeared. If it's just a permanent thing, oh well.
Anyone else have any insights?
02-25-2015, 04:44 PM   #4
Mine comes and goes, doesn't really bother me. But one time I had a bubble near the edge on a new camera that was stubborn, but I just pried up the edge very slightly and it went away instantly, then pressed the edge back down firmly. So you might try prying up a tiny area with a fingernail or thin piece of plastic and see if it will release the bubble -- just enough to let some air out.
acmaxx, bubble, edge, k-30, k-50, lcd, oil, pentax k30, pentax k50, pocket, protector, screen, solution
Screen protector for K-50 nyonya Pentax K-30 & K-50 15 03-01-2016 10:22 AM
ACMAXX LCD screen protector - reusable?? seventysixersfan Pentax K-30 & K-50 13 02-06-2014 08:28 AM
ACMAXX LCD Screen Protectors are different for K-5II models Docrwm Pentax K-5 & K-5 II 6 05-29-2013 08:15 PM
ACMAXX Screen protector jules Pentax DSLR Discussion 6 08-06-2010 12:07 AM
Acmaxx 3.0” lcd screen protector mba1971 Pentax Camera and Field Accessories 2 11-05-2009 04:23 PM
All times are GMT -7. The time now is 02:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
