Originally posted by fredralphfred By the way, shims -- it wasn't clear to me before, but after receiving the focusingscreen.com package, it comes with one plastic shim. I'm guessing (based on reading the directions) that it must be to compensate for a difference in thickness between the Nikon screen that they cut down and the Pentax screen the camera came with; it doesn't come with a "shim kit" to adjust the screen for good focus.
Your camera allows for a shim that fits between the screen and the bottom of the pentaprism under a separate retainer. There may or may not already be one in place. Conventional wisdom is to not fiddle with shimming unless you have reason to believe there is a need. I consider this to be particularly true in regards to the plastic shim(s) provided by focusingscreen.com. They are sort of flimsy and difficult to place. If you need to change the calibration, remove or replace the existing shim with one of more appropriate thickness.
To check calibration, I suggest you compare your best effort using the split image against magnified live view. Use a high-contrast focus test target placed
flat and parallel to the sensor at a distance of about 20x the lens focal length. There are several such targets available for free download on the Web. The important thing is that it have non-ambigous vertical lines. Figuring out how to adjust calibration (whether to add or subtract) may be difficult to visualize, but there are helpful diagrams on the focusingscreen.com Web site.
With any luck, the focus will be OK with no need to adjust. If adjustment is needed and the provided shim is not appropriate, contact focusingscreen.com for a different thickness.
