05-18-2014, 06:39 AM - 1 Like   #1
D1N0's Avatar
26mm F1.8 and F2 Patents for GR
Ricoh keeps on patenting new primes for GR. They should make it ilc.
Google Translate
Patents Ricoh 26mm F1.8 [optical technology and lens design]
Ricoh is 26mm F1.8 of the patent is pending.
embodiment1: 26mm f/2.0 (APS-C)
embodiment4: 26mm f/1.8 (APS-C)
Description and self-interpretation of the patent literature
  • Patent Publication No. 2014-81485
    • Publication date 2014.5.8
    • Filing date 2012.10.16
  • Example 1
    • Focal length f = 26.00mm
    • Fno. 2.00
    • Half angle ω = 28.81 °
  • Example 4
    • Fno. 1.80
    • Half angle ω = 28.8 °
GR family
GR The current Leica format equivalent 28mm (actual focal length 18.3mm) you can get the angle of view. The use of Waikon GW-3 21mm terms , the use of the crop in terms of 35mm , 47mm conversion can be used as.
If there is a GR family, angle of view that do not overlap is good. The optical system of the patent application is 26mm so, in terms of Leica about 40 mm . Once upon a time, Leica and Minolta is, the Rights Minolta CL for 28mm 40 mm 90 mm ​​because I was the lineup, 40mm conversion might be just good.
[0147], it is also suitable for use as "interchangeable lens camera for electronically interchangeable lens" by the unit as a photographing lens unit this.
The optical system of the pending, can also be used as an interchangeable lens for APS-C for so 14.3mm image height, but it would be for GXR GR or back focus is short. Seven pieces of six groups, lens configuration is two on one side aspherical. AF would be slow because it is a front group feeding.
performance
Example 1 Example 4 Inf Mod Spherical aberration, astigmatism, distortion, from left to right, vertical coma aberration.
Distortion is zero
Do not have a case "I do not know why, but for some reason appears to be high quality" and. One of the reasons is the distortion.
Pixel resolution, even if bad, rarely be a problem as long as reflected in the sharp viewing size. But only distortion is not changed even if reduced. If distortion of 1% if, confirmation of distortion will be difficult for example if 100 or the number of pixels in the diagonal direction, but confirmation of the image too difficult.
Example 1, F1.8 is a lens of F2.0 instead, but the distortion is almost zero. Because it is optically zero, there is no image quality degradation caused by digital correction of distortion. While the current wide-angle GR also called conversion 28mm, it was very little distortion. Straight line, so goes to a straight line, I seem to get a picture good feeling that was refreshing.
Tags: RICOH F1.8 F2.0 26mm
05-18-2014, 06:42 AM   #2
Aristophanes's Avatar
The GXR was ILC (or lessor) and I suspect that is Rico's plans for the GR series. Probably both a fixed lens and ILC variants.
06-02-2014, 04:58 PM   #3
Na Horuk's Avatar
so many patents, so few actual products..
But yeah, nice FoV and aperture.
06-03-2014, 10:43 PM   #4
i83N's Avatar
wish it was for FF sensor.
06-08-2014, 02:08 PM - 1 Like   #5
Few products. Ricoh makes quality product. I prefer a brand that release 1 great product over a brand that release tons of useless ones... ;-)
06-09-2014, 05:45 PM   #6
Banned
Ricoh (Imaging) has filed plenty of mirrorless patents for the APS-C. The best advice? Don't hold your breath.
26mm, angle, distortion, example, f1.8, gr, lens, patent, patents, pentax news, pentax rumors, ricoh
For Sale - Sold: Pentax 16-50mm F2.8, 50-135mm F2.8, and 50mm FA F1.4 Fred2726 Sold Items 15 01-04-2014 10:21 PM
For Sale - Sold: Prices lowered!!--- 'K' series primes: 30mm f2.8, 50mm f1.4, 55mm f1.8, 135mm f2.5 lightsleuth Sold Items 5 11-15-2013 07:23 PM
Pentax 60mm f2.8 FF(35mm) + 90mm f2.8 (645) Macro lens patents Steelski Pentax News and Rumors 43 03-15-2012 08:16 AM
All times are GMT -7. The time now is 05:47 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
