Show Printable Version 204 Likes Search this Thread
02-09-2015, 05:07 AM - 1 Like   #421
I'm not sure why is this so hard to comprehend... KS-1 is a replacement for K-500, KS-2 will replace K-50
Both K-500 and K-50 had the same sensor, only K-50 had WR, illuminated focus points, and that's about it
Now we have K-S1 with 20mpx sensor, same sensor will be in K-S2. Same AA filter simulation, same processing engine etc
Only that K-S2 will have WR, articulated screen, better handling - for more advanced users, built-in WiFi and NFC
To me, that sounds completely logical. K-3 is far from obsolete and will be the top level APS-C camera for at least another year.
When the FF comes out, it will be one step above K-3.
02-09-2015, 05:09 AM   #422
QuoteOriginally posted by simon_199 Quote
We should be rather happy about that, the sensor on the K-S1 seems one of its strong points. Furthermore this implies a rather affordable camera, priced way below the K-3. I hope there are some interesting features that make it special, maybe the re-introduction of video SR (the flippy screen might suggest video capabilities as a strong selling point ? ). I also hope some missing features on the K-S1 are back, like the electronic level, or the little known sensor-shift composition adjustment that the K-50 had.
I'm not convinced that really the S stands for special and that this line will be run in parallel with a more traditional SLR line, in which we should expect a "true" K-50 replacement... this one has nothing unconventional. Probably it's just a change in the naming scheme, maybe the K-3 successor will be called the K-S3
If the street price will be on the same level of the current K-S1 pricing (overpriced in my opinion), then i'll buy this K-S2, with its new compact kit lens which is a welcom addition for me as i don't have a single WR lens right now.
The K-3 had some big video improvements, and it was clearly aimed to appeal to videographers (to a certain extend). Yet they deactivated SR. So the problem is not the not trying or not caring, but the not understanding. I do hope they finally asked someone.
The K-S2 does look a bit flashy, unconventional. I could imagine that the K-50 successor will run in parallel, with similar hardware but a more conventional design. Less emphasis on WiFi, no LEDs, no brushed metal parts, ... maybe drop the flippy screen.
I really hope this isn't the K-50 successor. While it really could be, I liked the idea of a special line of cameras where they can experiment. Turning that into the mainstream line is disappointing.
---------- Post added 09-02-15 at 13:17 ----------
QuoteOriginally posted by ZeljkoS Quote
It is because that is not what they said the K-S line would be. The K-01 should have been the K-S1, with the K-S1 getting the K-S2 designation. The next K-S can be entry level again, or something completely crazy. That was the beauty of the naming scheme.
The real K-500 successor should have received it's own letter, and so should the K-50 and K-3 successor, as well as the FF. Then you can just count them through, never running into confusing naming problems again. Eventually Pentax can be at K-S49, and it's not an issue.
02-09-2015, 06:43 AM   #423
QuoteOriginally posted by kadajawi Quote
I don't recall the Ricoh representative saying the "S" and "non-S" lines would run in parallel, feature-wise. To me, it's increasingly looking like the "S" line will be entry level and mid-range which means the K-S2 ultimately replaces the K-50. The non-S line is shaping up to be higher level offerings. So, yes, the "S" designates an alternate design approach but I think the distinction is more than just that. If fact, we already saw a transition in this thinking with the K-30 gaining colors beyond black and then the K-50 came out in multiple colors on it's launch date.
02-09-2015, 07:07 AM   #424
Mistral75's Avatar
Pentax K-S2 will be announced tomorrow February 10th in Japan (tonight in Europe, this afternoon in the USA).
Some specifications:
- CMOS sensor with 20.12 million pixel (effective). No low-pass / AA filter
- PRIME MII Image processing engine
- Protected against dust and moisture; 100 seals
- Double dial
- Full HD video
- 77-segment metering
- Vari-angle swing-out LCD monitor
- Shutter button appropriate for selfies
- AF system: SAFOX X. AF array with 11 sensors, of which 9 are cross-type. Sensitivity -3EV
- Select-Area Expansion and AF-Hold features
- Highest sensitivity: ISO51,200
- In-camera shake correction
- Low-pass selector
- Supports O-GPS1 GPS unit
- Optical viewfinder with 100% coverage
- Fastest shutter speed: 1/6,000 sec.
- Continuous shooting 5.5 frames / sec.
- Wi-Fi built-in. Integration with smartphone
Source: Digital Camera Info http://digicame-info.com/2015/02/k-s2-1.html
02-09-2015, 07:12 AM   #425
Sounds like a very capable DSLR.
If I didn't buy K-5 IIs on Black Friday, I would be looking at this camera definitely
02-09-2015, 07:12 AM   #426
QuoteOriginally posted by IchabodCrane Quote
I believe there is a market for traditional entry level DSLRs, such as the K-30 and K-50. Yes, they have some design to them, but the K-S1 goes far beyond that.
What confuses matters is that the K-S2 is so... "conventional". I guess we'll just have to wait and see.
02-09-2015, 07:15 AM   #427
JinDesu's Avatar
5.5 FPS puts it above the two new Canons. No AA filter means it likely has the AA simulator on the k-3. Solid specs, hopefully at a competitive price to the recent Canon cams.
02-09-2015, 07:19 AM   #428
D1N0's Avatar
Differences form the K-s1 selectable low pass, SAFOX-X instead of IX (aside from the obvious differences we already knew about)
02-09-2015, 07:24 AM   #429
K-S1 also has AA simulator ( selectable low pass ), same as K-3 and now K-S2
02-09-2015, 07:25 AM   #430
Gps unit built-in? Ü
02-09-2015, 07:31 AM   #431
QuoteOriginally posted by Mistral75 Quote
- GPS unit O-GPS1
Source: Digital Camera Info Google Translate
Built-in astrotracer function?!?
02-09-2015, 07:35 AM   #432
Mistral75's Avatar
QuoteOriginally posted by AtitG Quote
QuoteOriginally posted by jedie Quote
(I have corrected my previous post)
02-09-2015, 07:36 AM   #433
JPT
I'm afraid not. It's compatible with O-GPS1. That's all it means.
02-09-2015, 07:47 AM   #434
kenspo's Avatar
K-S2 will have one neat feature, that i cant see mentioned above. I havent heard any other dslr that have this..But correct me if im wrong..AFTER all the specs are out there :P hehe
02-09-2015, 07:50 AM   #435
The " Super resolution by pixel shifting" stuff?!?
ambassador, bit, camera, excitement, ff, forums, future, grip, k-3, k-s1, ken, legacy, lot, pentax, pentax brand, pentax news, pentax rumors, pm, post, ricoh, screen, sensor, source, space, time, touch, wi-fi, wifi
K-3 Camera Icon type is coming up wrong in Flickr Exif! dcpropilot Pentax K-3 & K-3 II 2 12-20-2014 09:16 PM
That expensive case is coming with the K-01 chucuyuco Pentax K-01 5 03-10-2013 08:07 AM
Nature Spring is Coming Den Post Your Photos! 2 02-26-2013 08:41 AM
Is there anything coming to replace the K-5 KLSMpls Pentax K-5 & K-5 II 18 03-28-2011 05:26 PM
My Lent is over--new K-x is coming Ira Pentax DSLR Discussion 17 08-03-2010 11:22 AM
All times are GMT -7. The time now is 01:04 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
