Originally posted by kngraphic I've just order the K-1 and I wonder how to wireless control the FZG540 flash.
I used to put the flash in a soft box and activate with the build in flash on my K3 and K5II
Do you need P-TTL or do you know your away around studio lighting (manual)? If you use manual mode, then almost any generic radio trigger will work. The industry standard is pocket wizards, but even the newer cactus triggers have proven to be pretty reliable. Just set on in the hotshoe, one on the flash and get shooting. If you need P-TTL, then you'll need the rare P-TTL capable radio triggers of which I believe there are only 2. Or you can get yourself another P-TTL capable hotshoe flash like the 360 or 540, or 3rd party, that is capable of being a master or controller flash. Then you can use that like you did before with the pop up.
