Originally posted by TroutHunterJohn Hi all. I just received my GR II and blown away at how sharp this lens is.
Now my questions/problems .
1. When I set the camera to shoot in black and white and it seems to work well. But when I import the images into Lightroom 6, the image reverts to color. It is b and w for a few seconds, then it turns to color. Any ideas on that one?
2. Also, I tried shooting in DNG+ and can see the DNG and JPG files on the memory chip, but Lightroom won't recognize or pull in the jpg versions, Do I have some settings wrong on the camera or in LR?
Thanks!
Lightroom will by default import (or at least show) only the raw file when it sees both raw and jpeg versions of the same image. There is a setting in the import preferences called "Treat JPEG files next to raw files as separate photos" that can be ticked to see both versions in the library.
Any filters in the GR is applied only to the jpeg - the raw file is raw, after all - so when the raw file is imported you'll see the embedded jpeg preview file (with the filter) while Lightroom builds its own preview from the raw data. That's why you see it in b&w for a few seconds before it appears in colour.
As @denpapp said, a workaround is to shoot raw only and then develop the image in-camera. This creates a jpeg with a new name, which then Lightroom imports separately. The downside, of course, is that converting multiple images will be rather time consuming.
Originally posted by Eric Auer Question.
Since you are importing to LR anyway, Why bother having the camera set to B&W?
Wouldnt you rather do the conversion in LR and possibly other software (DXO Filmpack comes to mind)?
Just curious as that is how I work.
Eric
The reason is that some of the in-camera filters in the GR is hard to reproduce in other programs. Most notably this is true for the high-contrast b&w. A lot of people like the look of this setting - and even if you should be able to get similar results with DXO, it's much quicker to let the camera do the job
(I always shoot raw+ anyway - then I can use the jpeg if I choose, or treat the raw further if I need to.)
