08-27-2016, 08:19 AM   #1
Query on Contax CY-mount Zeiss on Pentax FF
Anyone using or know whether Contax CY-mount Zeiss lenses will work on the K-1?
08-27-2016, 08:25 AM   #2
RAART's Avatar
with correct replacement bayonet, yes
Zeiss Contax lens for Pentax cameras
08-27-2016, 11:09 AM   #3
You want to make sure that you are acquiring the MM version of the C/Y mount. That is the one with the f22 aperture printed in green.
08-27-2016, 11:19 AM   #4
Yeah... been doin' that. These are VERY nice. I've seen the Leitax adapter mounts, but on my APS-C I've used Metabones. Would probably look for something on that line first.
08-27-2016, 01:01 PM   #5
Otis Memorial Pentaxian
QuoteOriginally posted by jwmster Quote
Good luck...Metabones does not support Pentax-K. The reason why the comments above mentioned Leitax is that it is reasonable way to mount C/Y to Pentax-K while retaining full optical quality and infinity focus with the longer lens registration distance. AFAIK there are no adapters that allow both.
08-27-2016, 03:37 PM   #6
At this point I must mention the Adaptist PK+MM Multi-Mount, which I used to replace the stock K-mount on my K-30 and only looked back once (when I spent a summer week in Florida and couldn't afford to take chances with the weather sealing). There has been no official word yet on whether it is compatible with the K-1.
One advantage of the Multi-Mount over the Leitax method is that it works for all Contax/Yashica lenses, not just the narrow-mount MM ones. Also, the same mount lets you use Olympus OM and Nikon F lenses too. The only problems are the reduced weather sealing and the need to clip 3 mm off of the aperture actuation lever and guard if you want to shoot at anything other than wide open (though Adaptist claims this will not affect the lens's operation with a C/Y camera).
And I'm not just saying this because I couldn't get the last base screw off of my Planar 50/1.7 to replace the mount. Speaking of which, anyone know where I can get a tiny JIS screwdriver? Phillips apparently won't cut it.
08-27-2016, 05:15 PM   #7
QuoteOriginally posted by Scintilla Quote
Wow, if this thing is compatible with K-1,it can actually open up a whole world for me
08-27-2016, 06:42 PM   #8
QuoteOriginally posted by blan01 Quote
I would wait on the purchase until after your K-1 warranty expires. Also note that their product has not been tested with the K-1 for matters like mirror clearance.
08-27-2016, 06:44 PM - 1 Like   #9
Indeed...Phillips are not the proper cross-point drivers to use on a Japanese camera/lens. For a good selection of JIS:
Micro-Tools - Micro-Tools
08-27-2016, 11:17 PM   #10
Yes - JIS works much better. Also, during assembly at least one of the screws were glued in. I'v read that by touching the head of the screws with something like a soldering iron for an instant to break the bond, works well.
08-30-2016, 12:45 PM   #11
I believe these are held in place simply through tension, without a true lock for the lens. This was the largest turn-off for me.
24x36mm, contax, contax cy-mount zeiss, full-frame, pentax, query on contax, zeiss, zeiss on pentax
Query: Using Pentax lens on Samsung NX mount aruk5 Pentax SLR Lens Discussion 2 02-09-2013 10:50 AM
HELP! Contax Yashica mount CY Lens to Pentax K Hptx Troubleshooting and Beginner Help 8 06-03-2012 09:47 AM
35mm Zeiss Contax lenses on 645? atlnq9 Pentax Medium Format 4 01-01-2012 07:58 AM
Contax Zeiss Planar 85/1.4 on K10D aegisphan Pentax SLR Lens Discussion 6 04-03-2008 09:53 PM
All times are GMT -7. The time now is 10:51 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
