04-16-2014, 05:14 PM   #1
HDMI output same as LCD in live view?
I want to use a K-3 for some macro work plugged into a large HD monitor using the HDMI output. I need to be sure that live view outputs the HD signal at the same time as what is on the back LCD, anyone ever tried that? I need that feature for some delicate work because a 3" monitor is a little small for that. Thanks for any infos.
04-17-2014, 08:53 AM   #2
QuoteOriginally posted by VE2CJW Quote
Yes, it is exactly the same, which is both a good thing and a bad thing.
The bad thing about it is that you cannot get a clean output with no symbols, so you cannot use it to record on an external recorder. You can switch off most of the stuff but there always remains something.
It is however fine to connect to a larger monitor. Note that when you plug in the external monitor the LCD on the back switches off, but I don;t suppose you would need that once you can see it on the external monitor.
04-17-2014, 09:52 AM   #3
Thanks. This is really what I need. Take care.
dslr, hd, hdmi, hdmi output, k-3, k3, lcd, output, pentax k-3
K5 Live View: Live Exposure Adjustments Visible in "M" Mode? godwinaustin Pentax K-5 & K-5 II 6 08-13-2013 08:11 PM
K-01, HDMI and live view Hayflick Pentax K-01 6 12-20-2012 12:37 AM
K-01's HDMI output pundit Pentax K-01 2 03-17-2012 04:51 PM
Heat : Live View vs HDMI ajoe Pentax K-5 & K-5 II 5 01-25-2011 01:11 PM
Does Kr use same LCD screen as K5 and K7? texoma Pentax DSLR Discussion 7 01-24-2011 12:15 AM
All times are GMT -7. The time now is 02:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
