08-30-2014, 12:13 AM   #1
jbarry's Avatar
K3 In built flash
Could someone please enlighten me as to how to set the in-built flash to OFF............it appears to have every other setting bar this one
08-30-2014, 12:15 AM   #2
Erm, don't pop it up and it won't fire
08-30-2014, 12:45 AM   #3
jbarry's Avatar
thanks Adam, that simple................unlike the Kr which sometimes decides to add flash [when deemed necessary] and then it helps to be able to turn it off ahhhhhhhhhhhh
08-30-2014, 01:10 AM   #4
Master of the obvious
savoche's Avatar
Yep, sometimes it's so simple it's hard to spot. I really hate cameras that decide to pop up the flash unasked.
08-30-2014, 09:36 AM   #5
sherrvonne's Avatar
QuoteOriginally posted by savoche Quote
Ha ha, My mom's point and shoot camera kept doing that to me, it put a glare where I didn't want one. I didn't know her camera and if I could turn it off.
08-30-2014, 04:15 PM   #6
QuoteOriginally posted by jbarry Quote
Exactly right. The K-r's flash is electronically controlled, so it could pop up on its own. On the K-3 and other advanced bodies, the switch is mechanical so the flash won't fire unless you yourself pop it up.
08-30-2014, 05:28 PM   #7
jbarry's Avatar
Thanks Adam, that has truly cleared the issue
dslr, flash, k-3, k3, k3 popup flash, pentax k-3
K3 with built-in flash issue - any idea? AlexZav Flashes, Lighting, and Studio 6 03-01-2014 02:30 PM
taking photos with built in flash in extremely low light Andrew Crouch Pentax K-5 & K-5 II 12 02-20-2014 12:10 AM
K-r: built-in flash stopped working after using external flash wedge Troubleshooting and Beginner Help 7 01-12-2014 07:57 PM
Need to disable in-built flash when using off camera flash Molly Flashes, Lighting, and Studio 18 03-27-2013 04:12 AM
Trigger remote flash without popping up built in flash godavari Flashes, Lighting, and Studio 23 10-15-2012 01:32 PM
All times are GMT -7. The time now is 02:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
